Bolted Connection Custom Content Center parts Table not showing all columns
When I create a bolted connection using the content center parts I have created and go in select the "..." to choose which nut of that size I want, all I see is the below table.
But when I go to place from content center the same nut, all my Key Columns show up in the table. (Shown below)
My question is how do you get the bolted connection table to look like the "place from Content Center" table?
Thank you!
blair
You can't. The Bolted Connection function was added long after the CC was added. Perhaps in future releases, they might have enough resources to make both look the same.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Thanks!
hope they make that update because the bolted connection is nice, but without the table, it's hard to see the correct finish without looking at the ERP system first.
fce
I got the same problem. Any updates?
Best Regards,
Francisco
Chad_WieheSSZKH
I am encountering this same issue in 2024 version.  Has any resolution been found?  We stock fasteners in multiple finishes and would really rather not create multiple families just based on finish or even thickness in the case of washers.
