When I create a bolted connection using the content center parts I have created and go in select the "..." to choose which nut of that size I want, all I see is the below table.
But when I go to place from content center the same nut, all my Key Columns show up in the table. (Shown below)
My question is how do you get the bolted connection table to look like the "place from Content Center" table?
Thank you!
Solved by blair. Go to Solution.
You can't. The Bolted Connection function was added long after the CC was added. Perhaps in future releases, they might have enough resources to make both look the same.
Thanks!
hope they make that update because the bolted connection is nice, but without the table, it's hard to see the correct finish without looking at the ERP system first.
