Inventor Forum
Best way to reduce project size
3 REPLIES 3
428 Views, 3 Replies
After a few months working on a project, there are many files in the folder that are not needed or used anymore. Is there a kind of (autocad) purge thing to get rid of all unescecarry files?
3 REPLIES 3
JDMather
Are you using Vault or are you using Projects?
You could Save As>Save Copy as Pack and Go from top assembly (or drawing of top level assembly) into a new folder.
That will copy only the actual project into the folder (Uncheck Template, Libraries or whatever unnecessary stuff in the P&G.)  You might then rename the old folder as Archive, just in case, rather than deleting.
in reply to: JDMather
We don't use Vault, Each project has it's own project file/folder
If i just P&G the top drawing, I will miss all the other drawings, right?
IgorMir
No, you won't. That's if you don't forget to include the drawings (if they have been created already) as well.
The topic on P&G had been covered more than once on this forum. Please search for it.
Cheers,
Igor.
Web: www.meqc.com.au
Technology Administrators
