Inventor Forum
Content Center File
8 REPLIES 8
Message 1 of 9
GosponZ
625 Views, 8 Replies
Content Center File
Does anyone has problem with CC files. I was surprised that all parts looks like on this att. picture. If somebody know how to solve please help.
Thank you All
Inventor 2021
8 REPLIES 8
Message 2 of 9
johnsonshiue
in reply to: GosponZ
Hi! Please measure the distance between the origin of the assembly and the CC part geometry. I believe it is very big. The components are far away from the origin, exceeding the assembly valid model range.
Many thanks!
Software Test Engineer
Message 3 of 9
GosponZ
in reply to: johnsonshiue
This never happened before. I install Inv. 2021 and start doing this. Inserting screw wherever should be good screw.
Thank you for trying help  here is another shot
Message 4 of 9
johnsonshiue
Hi! Did you measure the distance between the CC part and the assembly origin? Please share the CC ipt file here.
Many thanks!
Message 5 of 9
GosponZ
Autodesk experts i need answer on this. Some parts are ok some not. Self drilling screws are ok.
Tags (1)
Message 6 of 9
johnsonshiue
Hi! Please share an example here or send it directly to me (johnson.shiue@autodesk.com). I cannot reproduce the behavior on my machine.
Many thanks!
Message 7 of 9
GosponZ
Ok here is screen shot and part is attached. Don't know what is going on
Message 8 of 9
johnsonshiue
Hi! I suspect your active Material and Appearance Style Library has custom appearance styles or corrupted styles. Open the CC part and go to Appearance Browser -> edit the style. "Cutout" option is checked, leading to "seen-through" behavior. Do you know why "Cutout" option is checked?
Many thanks!
Message 9 of 9
GosponZ
I figure out same thing. I worked on Inv 2020 and upgrade to 2021 and start happening. Never changed appearance for cut out. When open that appearance cut out is off, but only on few parts in cc is on. Very strange.
Many thanks for helping me
