Best design practice : Representing circular hole pattern in a drawing
baliasM74U3
baliasM74U3
Hi Experts
INV 2020
What is the best way/practice of representing a circular hole pattern in a drawing ?
Chancellor.Kurre
It depends on your manufacturing method. If these parts are drilled on a lathe with a dividing head I would dimension differently than if they were being cut on a laser. What is the method of manufacture?
CGBenner
@baliasM74U3  For flanges we always dimensioned using a Bolt Circle diameter, from the center point of the pattern to the center of the circles.  Then along with the BC diameter, we'd include a note stating how many holes at what size, and the spacing.  Example:  ø3/8" DRILL THRU, 16 HOLES EQUALY SPACED ON ø12" B.C.
Chris Benner
johnsonshiue
Hi! If I understood the requirement correctly, patterned center mark might be what you were looking for.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Inve...
Many thanks!
Software Test Engineer
