Inventor Forum
Bend lines not showing on drawing of a lofted part
2 REPLIES 2
374 Views, 2 Replies
I've created two parts to be placed on the outside of a silo so they are sort of off centred cone pieces, attached below. When i converted to a sheet metal part and created the flat pattern, there are no bend lines. There are also no bend lines if you make a drawing of the parts.
2 REPLIES 2
IgorMir
It is a rolled part with a twist. Where the bend would be?
Cheers,
Igor.
Web: www.meqc.com.au
johnsonshiue
Hi! The sheet metal part was created using developable spline surface (Loft). The unfolding was done by numerical process. There is no actual straight bend line.
Many thanks!
Software Test Engineer
Technology Administrators
