I've created two parts to be placed on the outside of a silo so they are sort of off centred cone pieces, attached below. When i converted to a sheet metal part and created the flat pattern, there are no bend lines. There are also no bend lines if you make a drawing of the parts.
Solved by johnsonshiue. Go to Solution.
Hi! The sheet metal part was created using developable spline surface (Loft). The unfolding was done by numerical process. There is no actual straight bend line.
Many thanks!
