Bearing in Assembly disappears in Drawing
Vagulus
Vagulus
In my Overbender project the IAM of the jackscrew includes the thrust bearing
Jack Screw with bearing (at extreme left)Jack Screw with bearing (at extreme left)
It is still present when I explode things in an IPN (second from left)
Exploded view in IPNExploded view in IPN
but it disappears when the IPN is put in a drawing
Exploded view as drawingExploded view as drawing
You will note that it shows up in the Parts List and that the circlip (7) has moved to the Bearing Carrier (2) - sorry about the part name problem, I'll get on to that.
Why the difference between Presentation and Drawing?
"If you can't explain it to a six-year-old,
you don't understand it yourself"
Albert Einstein
jhackney1972
I just opened your assembly and made the same presentation file you showed.  When I made the drawing, the bearing did not show.  Expanding the drawing browser, under the assemby you will notice that the AST Bearing is a showing as a surface part.  Right click and make it visible and you are good to go.
John Hackney, Retired
Vagulus
Thanks for the prompt response jhackney1972, but it is set as Visible
Visible is CheckedVisible is Checked
Albert Einstein
jhackney1972
Please note from my reply, I said to expand the "Drawing" browser not the assembly browser.  The screen shot is taken from the drawing browser.
Vagulus
One picture, they say
Jack Screw GAJack Screw GA
Albert Einstein
