Base View Indicator
Base View Indicator
inventor4578
Base View Indicator
inventor4578
Hi !
I have a very quick question :
How to know what is the BASEVIEW on my drawing ?
(By menu or by ilogic, vba....)
Thank you very much,
SharkDesign
Easiest way is to just look at your browser and it's the one at the top.
  Inventor Certified Professional
inventor4578
Ok thank you !
How to highlight by iLogic, or select by iLogic ? (or maybe add label)
Thanks you very much,
Regards.
mcgyvr
@inventor4578 wrote:
Ok thank you !
Regards.
Dim doc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = doc.ActiveSheet
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)'Select View for Item number
ThisApplication.CommandManager.DoSelect(oView)'Select View
inventor4578
It's working ! Thanks.
Another point can be how to unselect ?
I would like to make a blinking select so : Select/Unselect/Select....
Maybe without a wait command of 0.5 sec between each selection.
Best regards.
