Inventor Forum
Background Text Masking Problem ( Uncontroled Text Box extending)
4 REPLIES 4
1262 Views, 4 Replies
My company has discovered the new feature of Background Text Masking in Inventor 2018.
(Double click on Text>click the 'background fill button between 'text case' and , 'text box' button> choose color to fill the background. )
Problem:
After sometime of working well certain text boxes which just happened to have no leaders attached extended into infinity off the page.  Is there a way to control the text box itself?
kelly.young has embedded your image for clarity.
Problem:
4 REPLIES 4
okaleja
okaleja
Could you please provide some steps to reproduce the problem? Do you know when those boxes got extra big? If you could share the drawing which shows the problem it could help too.
Oto Kaleja,
Oto Kaleja
Software Engineer
Oto Kaleja,
Oto Kaleja
Software Engineer
in reply to: okaleja
Thanks for your reply, okaleja
I haven't be able to reproduce the problem.
It seemed to occur after using the update button.  (the update seemed to have taken a really long time)
I no longer have the drawing with the errors but the attached drawing is after I erased the text and redid the masking.
kelly.young
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous thanks for attaching the drawing.
When I opened it up it showed up just fine without the extended white area.
Do you have the most current updates applied for 2018? Not sure if something got corrupted or if you have a custom iLogic setup that might be affecting.
Could try Reset Utility or Repair Install as this doesn't appear to be normal.
I don't think there is a way to control the size of the text box on the main drawing view, if you create a Sketch and then Text, you can RMB and select Text Box you can set a dimension to that and Background Fill.
There are some trade offs from doing within the sketch but that might be another option.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hope that helps!
in reply to: kelly.young
Thanks, I found that solution too.
I think it was a type of corrumption of some sort.
I'm using only a TotalQty Ilogic rule and I don't think that would affected.
Thanks for the input!
