Announcements
Editing sketch breaks revolve and all associative parts
Hi all,
I've realised that I've drawn a sketch wrong and omitted a part of the design. When changing the sketch, the revolve associated with the sketch fails, then, as the revolve creates a face that forms the chain of a number of other parts, everything fall down. When editing the sketch, I only need to add a 'notch' into a corner, I'm not deleting the whole thing and re-drawing. I've read around that you can 'redefine' but when editing the revolve feature, I can't select the correct profile.
What's the best way to resolve this?
OLC
Replies (9)
jhackney1972
You need to attach your assembly and parts to your question so others can see what the issue is.  it is impossible to determine what is going on simply by reading about your problem.
John Hackney, Retired
So; RevolutionSrf MP is failing because its child, Sketch MP has changed. The Revolve forms a face upon which a Sketch is draw and so its associated extrusion and lofts fall down. I assume it's a simple solution, I just don't know the technique.
You have a line extending past one corner that is causing the problem.
Also look at your 15 dimension from the construction line, it is coming off the endpoint only, not the entire line2018-04-10_16-08-01.jpg
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous you should get into the habit of making any Revolve feature have a Centerline, where you currently have a construction line. This will generate diameter dimensions when you select it.
If you ever see that you have # dimensions needed in the bottom right corner, RMB on empty drawing space and select Show All Degrees of Freedom.
It will show you where you need to put some constraints.
@Anonymous is correct that you can just trim the line and make sure the dimension is to lines not point ends.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
johnsonshiue
Hi Aaron,
This one is not that hard. Edit Sketch MP -> you will see a line with fx:10 overshoots. Add a coincident constraint to close the profile and you will be all set.
Many thanks!
Software Test Engineer
Thanks all,
I think I must have edited the sketch with the visibility of the bodies beneath turned on making it harder to see the lines. I'm disappointed I'm still making these basic errors!
johnsonshiue
Hi Aaron,
No worries! You are more than welcome! We are all learning. I have been using Inventor for a bit less than 20 years. I still tripped myself from time to time. Maybe someday I can share my most embarrassing moment on using Inventor due to my own mistake.
Many thanks!
Of course, we only tend to come to the forum for advice, but this afternoon
I overcame a head scratcher. I'd drawn a sketch on the face of a surface,
but on rebuilding the surface as a body, the sketch became inoperable. I
couldn't even open the sketch to investigate! It took me longer than a
moment to work out why I couldn't edit the sketch!
johnsonshiue
Hi! This sounds like a bug to me. Could you share the file here or send it to me directly (johnson.shiue@autodesk.com)?
Many thanks!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
