Inventor Forum
Automatic filename generation based on custom parameter names and values when exporting to STEP
8 REPLIES 8
Message 1 of 9
860 Views, 8 Replies
I have a parametric model of a product. By changing the custom parameter values I can easily modify that product to actual needs.
I do not use vault but have a 'track and trace' procedure to always export that parametric model to a step file.
The name of the stepfile ought to be based on different custom parameters and their values. E.g. 'CS40,0 CWT2,0 CWST0,25.step' where CS CWT and CWST are custom parameter names each sequenced by its value in the parametric ipt model. In real there are some more parameters and values to the name.
Is there a way to automatically generate the name of this step file each time I export it from the parametric model. Now I have to take a piece of paper to note down the parameter (short memory failure) values to give it the correct name. Nevertheless the risk of making errors remains.
Looking very hard forward to a solution for this inconvenience.
Thanks & best regards
Wouter
Tags (1)
Labels (4)
8 REPLIES 8
Message 2 of 9
Daan_M
Yes you can do this with iLogic.
You can create a rule that translates your file to a step and give it a custom name.
You can use something like this
dim oDestPath as string = 'folder path location
dim oStepFileName as string = 'your parameters
SaveFile = oDestPath & oStepFileName & ".stp"
ThisDoc.Document.SaveAs(SaveFile, True)
Message 3 of 9
in reply to: Daan_M
@Daan_M  Thanks for your reply. I might need some more support to get the entire syntax right. I lack the experience here.
Thanks a lot
Best regards
Message 4 of 9
Daan_M
There's alot of people with extensive knowledge about iLogic here. If you can give more details i'm sure there will be a fitting solution.
Message 5 of 9
Jon.Dean
Hi, @Anonymous,
Do you need further help with this issue?
Jon Dean
Message 6 of 9
Here's the code you need.
I put in 2 lines for the file path, as it is, it will save the STEP file to the same location as the current file (with the naming convention you asked for). If you want the file to save to a specific location change the values in "oPath" (currently "C:\CAD\STEP Files\") and uncomment the 2nd oPath (remove the ' before oPath)
oParamnames = "CST" & CST & " CWT" & CWT & " CWST"& CWST & ".stp"
oPath = ThisDoc.Path ' use this line to save to current file location
'oPath = "C:\CAD\STEP Files\" 'make sure you include a "\" at the end eg "C:\CAD\STEP Files\"
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
    ' Set application protocol.
    ' 2 = AP 203 - Configuration Controlled Design
    ' 3 = AP 214 - Automotive Design
    oOptions.Value("ApplicationProtocolType") = 3
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
	oData.FileName = oPath & oParamnames
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
End If
Message 7 of 9
@Anonymous That worked fine, thanks alot!
I only had to 'comment' the           oPath = ThisDoc.path        for it to save to actual location. Don't know why.
Anyhow, this saves some work.
Best regards
Wouter
Message 8 of 9
econcore glad it works, please mark it as the solution 🙂
Message 9 of 9
Jon.Dean
Hi @Anonymous
Glad to hear all is well and the code is working for you.
Have a nice day.
Jon.
Jon Dean
