Change occurence name via ilogic
zoe.baker-bushby
zoe.baker-bushby
Within the iProperties of a circular pattern element there is the property: Occurrence > Name. Is there anyway to reference the Occurrence Name iPropertie so that you can alter it via illogic code??
I have some code that will rename ALL of the nodes in an assembly, including the pattern elements.
Have a look at the second bit of code here: https://clintbrown.co.uk/2020/07/29/ilogic-normalise-browser-nodes-with-code/
If you needed something more specific, you could find the names of the pattern occurrences, using something like the code I use to identify bolted connections in this post: https://clintbrown.co.uk/2019/02/10/ilogicbolts/
Hope that helps
zoe.baker-bushby
I had to do some rework of the code to achieve exactly what I wanted but nether the less your code helped and solved my issue so thank you!
