AutoDesk's failure to fix problems.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
18 months ago I posted on Tweaks / Presentation files, regarding changing the browser back to showing tweaks under the component(s). Has this changed in Inventor 2019 ? I have not loaded 2019 as yet, so I am unaware if this has been set back to USER friendly or not.
But the reason for today's submission stems from Autodesk's failure to "fix" it's Bolting Generator.
Googling "Bolting Generator" speaks volumes.
And due to not fixing the issues I am still wasting time doing things individually / manually, and then arraying.
So what do we all pay for annually ????
In 2009 (Inventor 2010) I had an bolting generator issue which was acknowledged by Autodesk Asia-Pacific (in Malaysia), I had contact / response via my re-seller, and actually was contacted directly by Auotdesk Malaysia. (I am Australia based)
I was told the issue should be fixed by at least Inventor 2012 - well imagine my surprise when it was not - and is STILL NON FUNCTIONING IN Inventor 2018. and the original issue has had "upgrades" - as extra issues the generator now Fails to see holes in parts downloaded from supplier's websites, i.e. ex STP or IGES and converted to .ipt / .iam,
it does not see the holes when using "By Hole", but if you use "Concentric" it can find a circular form, but then "fails to create hole" ?????? and also (therefore) cannot "follow pattern" in the supplier part.
Why does this function always try to create a hole - I am old school - came from a drawing board using ink and a razor blade (to correct errors), so all parts had to be drawn with holes, and when I manufactured those parts I would have to drill holes in each part before being able to bolt parts together. You could not glue the parts together and then "wish" the bolts and holes into the parts / assembly.
Funnily enough I still use this concept in creating virtual 3D parts - I create a finished part with all holes, grooves, notches, chamfers, etc etc.
Your bolting generator will place holes in blind components - hence the "create hole" issue - this is a great idea, but it is absolutely useless in the real world, although probably good for users who are not much more capable than trained monkeys.
Try to use your concept real world - If your car had a flat tyre, does your spare come without the mounting holes and you drill them on the spot???? I do not think so.
If you set a blind hole in your own part(s) it will use an algorithm that determines your hole is not deep enough for the thread size selected, then turns this hole into a through hole, over-riding MY DESIGN, and as an engineer, fitter and machinist, and 30 plus year 'veteran' of drafting, I think i can design something accurately - but the response from your customer service personnel of Autodesk China was to use the "through hole" option and then edit bolt length dynamically.
Why not just fix your errors???????????????????? and give users the option of turning off the algorithm.
Autodesk China also pointed out that the 2x bolt diameter algorithm is the absolute minimum thread length for securing a bolt, - which holds no creedance when you examine the fact that even a high tensile hex nut has a minimum length of 0.8x thread diameter - and wheels seem able to stay attached to cars, trains, even aircraft !!
Dealing with Autodesk via the web-page or with re-seller support does not seem to achieve any result, so I have placed this post publicly in order to see what response follows.
And I think users and re-seller support staff are all past the need to find work-around solutions for your faulty program sub-routines.
I have used Inventor since version 2008, and AutoCAD since version 2.5 - i.e. early 1980's pre any version of Microsoft Windows - and undoubtedly AutoDesk has good product(s), and I have used other CAD packages and do prefer Autodesk.
So I ask Autodesk as 1 of 3 users in a sea of millions of users - what does my employer pay for every year ???
