Custom Quick Access Toolbar
Message 1 of 9
Hi
Is their a way ? i can add an shortcut for saving the drawing as PDF to QAT ?
I convert all the Drawings to PDF every time , so i know the keyboard shortcuts but still i think having an single click for this would save me time Smiley Happy
Replies (8)
Message 2 of 9
-niels-
Yes:
Go to Tools > customize
On the "Ribbon" tab select "application menu" from the first dropdown and set the target panel to something in the drawing environment. (i used Drawing / tools)
Search for the "PDF" logo in the first column and add it to the desired panel.
It will show up on that panel when you have an document where that panel is available, from there you can add it to the QAT.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 9
thank you @-niels-
Message 4 of 9
SEC_MECH
@-niels- THANK YOU SO MUCH for posting this. I now have "Save All" and "Close All" on the Quick Access Toolbar. 😁
Message 5 of 9
Sorry to reply to such an old thread, but I'm having trouble committing the changes I've made. Every time I start a new Inventor instance the ribbon resets to the default version. I've attached an image to show the kind of changes I'm trying to make, for context.
inventor_config_capture.jpg.
Message 6 of 9
-niels-
@Anonymous I'm still on IV2021 so i don't know if it's different (or bugged) in IV2022.
I'd start by trying to see if any change will stick, so move the menu bar and then close down Inventor to see if that works.
If it doesn't i'd try the QaT customization without moving the menu bar.
When none of those change will stick then i'd suspect it could have something to do with user rights on the system.
(writing to registry and such)
Maybe @johnsonshiue can make a better suggestion?
Niels van der Veer
The Netherlands
Message 7 of 9
I see, that would make sense, I think, as this is on my work computer (haven't tried yet on my home one). Thanks for the help!
Message 8 of 9
johnsonshiue
Hi Folks,
I am sorry I don't have a better suggestion or an explanation.
Many thanks!
Software Test Engineer
Message 9 of 9
Okay it turns out it's something like if you have multiple sessions/instances of Inventor open, whichever is closed last is the one whose changes are committed.
So each time I tried I must have had one in the background open, which I inevitably closed after the one I was actively using and customized.
Seems a little funny it would work this way, but at least it makes sense.
