Autodesk Inventor won't run on Windows 10 without a HotFix
- Mute
- Permalink
- Report
I have Autodesk Inventor Professional 2012 that was part of my licensed Autodesk Ultamite Product Design Suite 2012 that Have had working on my Windows 7 computer. I retired this last year but I still work PT on some projects that I worked on FT. I recently installed Windows 10 onto my computer. All the rest of the programs from Autodesk Ultimate Product DesignSuite 2012 I have been able to get to work on the new Windows 10, but when I tried to start Autodesk Inventor Professional 2012, I got an error message "The application is unable to start correctly (0xc0000142). Click OK to close the aapplication As I said it worked perfectly before on Windows 7. I tried to reinstall over the old program, Reinstall Fix the Program, and uninstall old program and reinstall new, same error code. I hope that enought others have the same problem so that Autodesk can maybe write a Hotfix. Now that I am retired from Full Time, I can't afford to get a new license for Inventor that I will probably only use for a couple years at most. the fix from Autodesk for windows 8.1 doesn't help because then it doesn't see Invenor at all installed, even though it theoretically is.
Thank you for any help in this matter, No one locally can help me because most other companies around use SolidWorks.
stevenabarnes@juno.com
