- Mute
- Permalink
- Report
Autodesk Inventor 2009 has stopped working - Windows 7 64 Bit
I have recently installed Autodesk Inventor Pro 2009 on my new PC running Windows 7 64 Bit. (about 8 weeks ago) Today I received an error message when attempting to run Inventor. The message window said " Autodesk Inventor 2009 has stopped working" then another windows said " A problem caused the program to stop working correctly. Windows will close that program and notify you if a solution is available"
Here are a few observations that might help:
The program had been working perfectly.
I had Internet Explorer running a YouTube video in the background has I attempted to start Inventor. I feel like a dummy for doing that even though that may not be the cause.
Also; I had one issue that I think was fixed about 3 or 4 days ago with a patch designed to stop Inventor from asking for new activation codes. I have not had this issue again but I will have to wait a while to see if that patch worked for sure but I think it did.
I saw that this error message can be an issue with different Autodesk programs and operating systems so I thought it would be best to start a new post for this.
Thanks in advance,
Bill
Autodesk Inventor Pro 2009 - Windows 7 64 Bit - 8GB Ram - I7 Processor
