There doesn't seem to be a hotfix for this problem. Has anyone else experienced disappearing dialog boxes, drop-down menus and RMB menus? They apear for a few seconds, then disappear. If I hover the mouse where they used to be, they will partially show up again and I can sometimes make a selection or click a button, but I usually have to start over and do what I'm trying to do quicker, before they disappear again. VERY annoying.
As for the driver certification issue... The latest driver from ATI is v7.2. It's working (other than the above mentioned issue) but Inventor says it's not certified. Inventor lists v6.4 as the certified driver. I've downloaded v6.4 from both Autodesk and ATI, and neither will install. It will extract and start the installation process, but then I get a dialog box that says:
SEVERE
INF file not found.
When I click OK it says (paraphrasing):
Unable to install video driver. Try installing a standard VGA driver before running setup.
I've wiped the computer of all ATI drivers and programs, going back to default drivers, but I still get the same error when I try to install v6.4
Any help is greatly appreciated.
