Assumed connection in sheet metal needs a tighter radius?
Message 1 of 13
so im working on this (attached) in sheet metal mode and the two metal parts recieved an assumed bend and that isnt a problem, the problem is the radius is /24 and we want it to be .15, how can i fix this?
Replies (12)
Message 2 of 13
mdavis22569
What's the thickness of your material?
Mike Davis
Message 3 of 13
i just used the face tool on a sketch and went with what it gave me, if in inspect the thickness is .12
Message 4 of 13
mdavis22569
attach your part...
what version of Inventor
also if you have a thickness of .12 ..and your radius is twice that ... you might want to change your thickness (sheet metal default) to .075 so it'll be a .15 outside radius and a .075 inside radius...
That's typically how bends work
Mike Davis
Message 5 of 13
JDMather
So what do you really really want the Thickness to be?
Sheet metal bends are normally specified to the inside radius - not the outside radius.
Both the Thickness and Bend Radius can be set in the Sheet Metal Styles.
Message 6 of 13
sorry i am really new to sheet metal modeling, i am great with normal 3d but i dont know... i have attached the part and will try what you said
Message 7 of 13
mdavis22569
start there with the right thickness you're looking for ...
Mike Davis
Message 8 of 13
JDMather
@Anonymous wrote:
... i am great with normal 3d ...
Sketch1 is not using obvious symmetry about the origin.
Sketch2 is not fully defined and has a dangling line underneath a boundary line.
Sketch3 is not fully defined for the position of the holes.
Back in a minute with a "repaired" file.
Message 9 of 13
i sort of kind of changed it and changed the thickness
Message 10 of 13
mdavis22569
you now know how to change the thickness ..
however as JDMathers said you have other issues to fix in the ipt ...
Mike Davis
Message 11 of 13
will these mistakes ruin the product or is it more stability issues?
Message 12 of 13
i believe i see exactly what you mean, i the file and exported it to stl and then reopened it with inventor and it does seem a little messed up
Message 13 of 13
Okay so as the community has said there are problems with the part file... i honestly have no idea what they are and i am so sorry for wasting your time and i thank you all for helping me with this... i have attached all my files, which includes .IPTs of 2 parts, .DWGs of both, .STL format of the parts, and PDFs of both DWGs, i know alot of this seems useless but the final result will be the STL and PDFs which would make them needed... i really want to fix it myself if someone could take the time to tell me what to add please? I reread the reply with details as to what i did wrong and it is actually very clear what i did wrong
