Hello ,
i´m a beginner in the inventor sofware, i,ve seen some tutorial videos, and forum; i´m tryin g to do a dinamic analisis in the inventor, placing an antenna rotating in thr top of a steel lattice tower.
I´ve an assembly file where i´ve the antenna that is rotating in the right way, in the same file i inserted the tower through the "insert frame"
I need help to place the antenna rotating in the top of the tower ( in the geometric center of the tower ), to do a dinamic analisys to calculate the maximum displacements.
The tower as the correct profiles and the antena as the correct weight, although the center of gravity isn´t right.
tanks in advance.
Hi!
Your attached file is only an assembly, missing the .ipt files (actual parts). Can you please attach them so that I can help you fix the problem?
Also, could you please restate your problem?
Woozy
Hi Woozy,
Thank you for your concern, i´m doing a academic work, wich consist in a mettalic tower with 45 m hight, and section 3x3 m, in angles of steel S355.
Mainly i´m using the robot strutural analysis, but to preform a more profund analysis i´m trying to do the dinamic analysis in the inventor. It´s dificult to me because it´s thr first time i´m working with the inventor.
I draw the antenna in the autocad 3D, then with the help of tutorial i did the assembly of the antenna, wich wheights abou 170 Kgs in the helix, and the motor, about 230 Kgs.
I design the tower in the autocad 3D, and then exported the file to the inventor and designed the frame.
I want to place in the top of the tower ,in the geometric centre the antenna rotating with velocity of 2pi rad/s.
The i want to preform a dinamic analysis.
I´m attaching all the files, ipt files, and the iam files.
Please help me to assembly these files to preform a dinamic analysis, of the atenna rotatting in th top of the tower.
thanks ,
Luis.
