animating a chain
- Mute
- Permalink
- Report
Hi all!
I want to create and animate a chain.
The first step is to create path and constrain one link to the path.
I created pattern with two work points with variable distance between them and attached the link to the path
When animating the distance variable will increase and the link will be moved.
I have set 3 constrains for the link
=link + XY plane
=center point of the link + to the second work point of the pattern
=transitional constrain to the extruded surface of the path loop
When I run it in the studio I get the following error
In the topic https://forums.autodesk.com/t5/inventor-forum/chain-link-animation-issues/m-p/10338614
The problem was solved by making the path adaptive.
In this case it didn’t help.
Here is the screencast https://autode.sk/3uc21eo
Thanks!
