Custom Panel
Custom Panel
engilic
Custom Panel
engilic
Is it possible to make or add a custom panel beside the standard ones?
Have a lovely day.
Chancellor.Kurre
It can be done programmatically for things like add-in creation, though I do not know if it can be done manually. What is the outcome you're looking for?
engilic
Thank you @Chancellor.Kurre,
I want to make the Panel with all the buttons I use if they can fit the screen, and hide or remove all the other Panels.
Programatically will do if no other way.
By the way: why I have level 8 (the person asking a question and not having the knowledge) and you have level 7 (the person answering and having the knowledge)? I should have level 3, maybe 4. Can I request a change?
Chancellor.Kurre
Just adding the extra tab programmatically would leave you changing it in every environment(drawing, part, assembly). This may be what you want, but it should also be possible  to pre-load these options. In any case, I'd try making an add-in that would just customize the ribbon. That way with any future installs or resets you just have to load in the add-in. Brian Ekins has a pretty good template that should be fairly straight forward with a bit of coding knowledge, or the people over in the customization forum may be able to help.
https://forums.autodesk.com/t5/inventor-customization/bd-p/120
https://ekinssolutions.com/wp-content/uploads/2018/11/CreatingInventorAddIns-AU2018.pdf
https://ekinssolutions.com/nifty_addin_template/
engilic
Thank you @Chancellor.Kurre ,
Would like to have one custom Panel for each environment but with different buttons inside.
Will take a look at the links you provided.
