Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
animating a chain
animating a chain
Message 1 of 11
animating a chain
Hi all!
I want to create and animate a chain.
The first step is to create path and constrain one link to the path.
I created pattern with two work points with variable distance between them and attached the link to the path
When animating the distance variable will increase and the link will be moved.
I have set 3 constrains for the link
=link + XY plane
=center point of the link + to the  second work point of the pattern
=transitional constrain to the extruded surface of the path loop
When I run it in the  studio I get the following error
In the topic https://forums.autodesk.com/t5/inventor-forum/chain-link-animation-issues/m-p/10338614
The problem was solved by making the path adaptive.
In this case it didn’t help.
Here is the screencast https://autode.sk/3uc21eo
Thanks!
Replies (10)
Message 2 of 11
johnsonshiue
Hi Anton,
This case can be done in multiple ways. Based on your assembly, I added an adaptive sketch point. Then redefine Workpoint1 to be based off the sketch point. Then add a Mate constraint, DriveMe between the Workpoint1 and the YZ plane of the assembly. Simply animate the DriveMe constraint will make the chains move.
The idea is just to have a constraint to drive geometry (sketch point and the workpoint), also the component pattern.
In your case, you only have the female chain links. You don't need to use pattern of pattern. The reason why other cases need pattern of pattern is because there are female and male chain links.
Please take a look and see if you have additional questions.
Many thanks!
Software Test Engineer
Message 3 of 11
gcoombridge
Have a look at the chain assembly here: http://www.cbliss.com/inventor/Parts/Hardware/index.htm
This site has been around forever but the chain is very cleverly pug together..
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Message 4 of 11
@gcoombridge , thanks for  your reply!
@johnsonshiue  thank you.
There are 2 issues
1)When I run your project, I get the following:
2)
The result I desire is in the file of the above mentioned post.
I have attached it to this post.
I don't understand why my project doesn't work and the project from the above mentioned post works.
They look alike.
The idea is to allow driveMe variable to increase endlessly, which allows to move chain along the path endlessly
Thanks.
Message 5 of 11
Hi @JDMather
Could you please help me with this?
This is a solved thread.
You should start a new thread with a link back to this one for reference.
Done.
Thank you!
Message 6 of 11
The solution is simple.
When I used manually created path it didn't work,
when I use the path made with design accelerator it works.
@JDMather ,
could you please explain this behavior ?
Thanks!
Message 7 of 11
3D4Play
Fireworks and fanfare every time someone references to the OG Charlie Bliss site. I wonder how big his kittens are, and if he ever found that magneto switch. One of these days, I'll go to his site, and get a 404, Shudder at the thought. LOL!
Message 8 of 11
j.palmeL29YX
The answer depends on what you want to achieve and what the animation will be used for.
As an example, using the Dynamic Simulation you can get animations that looks very realistic (see attachments).
Or following >>this tutorial<< you get an animation in Inventor Studio.
What is your goal?
Jürgen Palme
Message 9 of 11
@j.palmeL29YX hi
I have almost solved my issue,
but I would be happy to learn another new approach.
I have seen the tutorial you have had provided me with.
Do you have tutorials for chains in videos?
Thanks!
Message 10 of 11
j.palmeL29YX
@Anonymous wrote:
@j.palmeL29YX hi
You will find a lot in the web, e.g. at youtube you can search for inventor+animate+chain or similar keywords. You will find any good suggestions.
Jürgen Palme
Message 11 of 11
Yes, I have seen lots of them.
Some of them good, some not.
I am asking for tutorials for these specific videos.
According to your reply you don't have them))
Right))
