Inventor Forum
an error occured whil sending the request
9 REPLIES 9
Message 1 of 10
nstevelmans
553 Views, 9 Replies
Hi all,
I got this message when i want to upload the design.
see also screenshot
i have installed update 2019.3 ?
anyone an idea?
see also screenshot
9 REPLIES 9
Message 2 of 10
JDMather
in reply to: nstevelmans
Upload the design to where?
Message 3 of 10
Cadmanto
Sending what request?
Uploading what to where?
Need more detail.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 10
nstevelmans
in reply to: Cadmanto
Sorry,
i was sending it as shared view?
Message 5 of 10
Cadmanto
See if this link helps you.
https://forums.autodesk.com/t5/inventor-forum/problem-generating-shared-view/td-p/8427458
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 6 of 10
nstevelmans
well I have deinstalled all service packs and install the 2019.3 back again.
butt no luck?
Message 7 of 10
Cadmanto
Did you thoroughly look through the link I posted?  Seemed like there was some pertinent info in there for you.
Inventor Pro 2018
Best Regards,
Scott McFadden
Message 8 of 10
nstevelmans
Yes installed 2019.2 back again but no luck
I think it will be a reinstall.
Message 9 of 10
xianhua.chen
@nstevelmansdo you have any customized add-in loaded? If yes, could you try unload that add-in and share view again?
If no, could you send me the "Inventor.exe.config" file under Inventor installation path? By default it is in folder "C:\Program Files\Autodesk\Inventor 2019\Bin". This is to check the file version to see whether it is correctly updated.
Xianhua Chen
PDMS Quality Assurance Team
Autodesk, Inc.
Message 10 of 10
nstevelmans
in reply to: xianhua.chen
disable the add-ins did the trick, I must figure out which add-in was the problem great tip thanks
Technology Administrators
