Hi all,
I got this message when i want to upload the design.
see also screenshot
i have installed update 2019.3 ?
anyone an idea?
see also screenshot
Solved by xianhua.chen. Go to Solution.
Upload the design to where?
Sending what request?
Uploading what to where?
Need more detail.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
See if this link helps you.
https://forums.autodesk.com/t5/inventor-forum/problem-generating-shared-view/td-p/8427458
Inventor Pro 2018
well I have deinstalled all service packs and install the 2019.3 back again.
butt no luck?
Did you thoroughly look through the link I posted? Seemed like there was some pertinent info in there for you.
Inventor Pro 2018
Yes installed 2019.2 back again but no luck
I think it will be a reinstall.
@nstevelmans, do you have any customized add-in loaded? If yes, could you try unload that add-in and share view again?
If no, could you send me the "Inventor.exe.config" file under Inventor installation path? By default it is in folder "C:\Program Files\Autodesk\Inventor 2019\Bin". This is to check the file version to see whether it is correctly updated.
disable the add-ins did the trick, I must figure out which add-in was the problem great tip thanks
