Hello! Tell me please how I can align the specification of assembly?
@Anonymous
Welcome to the Autodesk User's Community..
Are you referring to making sure the parts list of the drawing doesn't fall off the drawing sheet?
Or something else?
Mark Lancaster
& Autodesk Services MarketPlace Provider
For starters, make sure the info feeding the parts list is a single line. Which means shortening your descriptions and part numbers and what ever other info is being fed into it that takes up more then one line.
Then, I would change the direction of the parts list to run up instead of down. That way the bottom edges will all line up and be able to be constrained to the bottom border edge.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Good advice. It also looks like the list is being divided at random intervals, better to let Inventor divide it into 5 columns.
If you go to the parts iProperties, as shown below,
you can change it here as shown below.
This will auto feed your parts list. Unless you have a custom parts list that you have different properties feeding it.
Inventor Pro 2018
