Inventor Forum
Adjustable"zigzag" plate
12 REPLIES 12
Message 1 of 13
Rasmus.C
1740 Views, 12 Replies
Hi everyone,
I am finding it surprisingly difficult to model an adjustable "zigzag" plate similar to the attached picture, and would greatly appreaciate some suggestions. Before covering my efforts, here are the fairly simple requirements for the part:
  1. Adjustable bend angle, pitch (distance between bends) and total number of bends parameters - to be able to control the final (bent) plate length and surface area.
  2. The end flanges needs to be colinear / flat, so that the plate may easily be attached to a frame, without being sensitive to the bending tolerances.
If you care, this is what I have attempted (unsusscesfully) so far:
  • Contour flange + rectangular pattern. Problem illustrated in attached screenshot.
  • Sketch pattern. Making a rectagular pattern of the desired "V" shape does not constrain them together, and Inventor only recognizes individual triangles / "V"s.
  • Connecting two contour flanges with a bend + rectangular pattern. Inventor does not like patterning bend features (even though parent is also being patterned).
  • Creating multiple contour flanges (edge extend) and using iLogic to adjust the final number by feature suppresion. This makes it difficult to model the final flange, which should be colinear with the first flange.
The most relevant similar example I could find was this issue, but the nature of the zigzag plate has made it difficult to make rectangular patterns viable for me thus far. Looking forward to your thoughts and suggestions!
12 REPLIES 12
Message 2 of 13
-niels-
in reply to: Rasmus.C
Something like this?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 13
JDMather
in reply to: -niels-
Broke on my first test?
Message 4 of 13
-niels-
in reply to: JDMather
Ah, yeah... only works with uneven numbers...
Back to the drawing board... eh, pc... Smiley LOL
Niels van der Veer
The Netherlands
Message 5 of 13
Rasmus.C
Hi Niels,
Thank you very much. I think that might actually work. I did not think about sketching the radius to ensure that the face would be perpendicular to the next.
I will attempt to create the part and return with feedback.
Best regards
Message 6 of 13
-niels-
Ok, retry... this should work better. Smiley Happy
Niels van der Veer
The Netherlands
Message 7 of 13
Rasmus.C
Thanks Niels,
Sketching the radius works out nicely, and the contour flange works well with rectangular pattern.
Message 8 of 13
SBix26
I see I'm a little late to the party, but here's my model, very similar to Niels' version, although I didn't actually use any Sheet Metal tools (except Flat Pattern).
Sam B
Inventor Professional 2018.2.1
Windows 7 SP1
Message 9 of 13
WHolzwarth
in reply to: SBix26
Hmm. I've tried a Studio animation.
But this silly error message (see video) was a show-stopper
Walter Holzwarth
Message 10 of 13
Delete the Flat Pattern.
Message 11 of 13
Doesn't help, Jeffrey
Walter Holzwarth
Message 12 of 13
I didn't try this, but what if you
and
Environments>Convert to Standard Part?
Message 13 of 13
Excellent advice, Jeffrey.
That did it.
Walter Holzwarth
