I've recently drawn a cylinder with a jog and overlap in sheet metal design using inventor 2017. The cylinder dimensions are 2" dia., by 4-3/4" length. The material thickness is 22 Ga. The jog is Thickness*1.1, and the overlap is 1/2". I made 8 triangle cut patterns, 3/4" long around the perimeter of one end creating tabs. My intent is to bend or fold the tabs outward to form a flange I haven't been able to figure out how to craw a sketched bend/fold line on the surface of the cylinder to fold the tabs outward. Is it possible to do this in inventor?
Can you share the model ...
Also why not make one flange and pattern about it ...then do the flat pattern?
It's not possible using Inventor's sheet metal tools. A bend is by definition a straight line.
But I'm not sure how well this would work with real sheet metal, either, and for the same reason-- how can this be bent around a curve? The piece would become octagonal at that end if you bent those eight tabs 90° out. If that's OK, then you could model it that way, with a lofted flange.
Sam B
Inventor Professional 2017.4
Vault Workgroup 2017.0.3
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
Can you post a photo of the actual part? The tab bends, before the rolling process, are straight lines. I can't imagine how they could become curved with that amount of material to stretch, so I assume that they remain essentially straight lines, and that end of the piece is an octagon. How close the transition to round occurs is dependent on the rolling process, though.
Sam B
Can you share what you have ....
I want to play with it some ...
Hi mdavis22569-----This is what I have so far. Hope you can do something with it, and have fun.
Hi Sam-----I don't have an actual part built as of yet. I'll post a photo when one becomes available. The tin can be stretched with a hammer and anvil. If the end does form an octagon I could decrease the size of the tabs and add more of them. I usually do have enough play in tin.
I think the idea is to attach a *.ipt file here rather than a mere image file.
Are you familiar with the Contour Roll command?
Unfold/Refold?
Here's one way (Inventor 2014)
I used Contour Roll, Unfold, Extrusions, Patterns, and Refold.
Steve Walton
