Add the Sketch Symbol Library Folder to the Folder Options in Inventor Project
fstiger281
Message 1 of 13
fstiger281
I would like to move the Sketch Symbol Library Folder available to a location where all users have access to, to be more specific, I will be moving it to Vault but I would like to incorporate the path to the existing Inventor Project, so the users have by default the right path set without them having to manually change it in the Application Options.
Is there a way to add the Sketch Symbol Library Folder to the Folder Options in the Inventor Project?
If there is not or what is the best way to move the symbols to Vault, so all users have access to them?
Inventor 2013, Vault 2013 64-Bit Edition
Windows 7 -64-bit
Replies (12)
Message 2 of 13
CGBenner
@fstiger281
Hello!  The Sketch Symbol folder can be set in your Application Options under the Files tab.  But... the location cannot point inside of the Vault, the files will need to reside somewhere local or on a shared drive.  My best advice would be to create a location on a shared network drive, place all of your symbols there and then make sure that for all users, the location is mapped in Application Options.  Then,... back them all up to the Vault.  If changes are made or new symbols added the Vault can easily be updated to keep up.  Good luck!
Chris Benner
Message 3 of 13
blandb
It has been placed into the Ideas station multiple times, hope one day it gets moved there lol.
Autodesk Certified Professional
Message 4 of 13
fsdolphin
Same user, different account, sorry:
Thank you for your reply.  As I said in my original post, what I'm trying to avoid is having to update each user's machine to update the Application Options.  I know the paths cannot point directly to the internal Vault paths, but it can point to a local folder in the working directory, I don't see why it couldn't.  In fact, even though it looks like the option to add the folder path directly to the project is not available, my plan is to upload the library to Vault and have each user download it to their local working folder and map each user manually in the Application Options. Thanks.
Message 5 of 13
CGBenner
@fstiger281 @fsdolphin
This explains why I was so confused...
I did gloss over some of the details in your original post, and I apologize for that.  But, as of now... adding the path to the Project is not possible as far as I know.
Chris Benner
Message 6 of 13
Frederick_Law
It's inside "Design Data".
I have "Design Data" in Vault to sync Style with other user.
In Vault:
Message 7 of 13
fstiger281
@Frederick_Law, does Inventor points you to that location by default when you insert a symbol? I tied it and it defaults to the folder specified in the Application Options.
Windows 7 -64-bit
Message 8 of 13
fstiger281
@CGBenner - Sorry about the confusion about the different user accounts.
Windows 7 -64-bit
Message 9 of 13
Frederick_Law
Don't know.
I put all Symbols in the drawing Template.  Old school, Symbol Library is "new".
Does the Project file point to Vault location?
PS:  Yes, it still use location in Application Option.
All user have to manually set it to "Design Data" location in Vault: C:\Vault Workspace\Design Data\Symbol Library\
Message 10 of 13
fstiger281
Ah, got it, makes sense. Thank you for the clarification.
Different question, how hard was it to move the Design Data folder to Vault? I remember trying to move it and I ran into issues. Just to be clear, I dragged and dropped the Design Data folder in Vault and changed the path in my project and didn't work, it has been a few months, but it said something about not being able to manage styles from Vault and I gave up. Do you have any recommendations on how to move the Design Data folder to Vault? Any tutorials you followed, anything. Thanks.
Windows 7 -64-bit
Message 11 of 13
Frederick_Law
Where was the "Design Data" folder?
Dragging to Vault means Check In from that location.
Most likely it's not in Vault Workspace.
Copy "Design Data" to Vault Workspace first then Check it In.
Message 12 of 13
Frederick_Law
Message 13 of 13
fstiger281
The Design Data folder was in our share drive, from there I dragged and dropped it to Vault. Thank you for the link, I will dig into it more.
Windows 7 -64-bit
