I am trying to make a brush in inventor and I am having trouble setting a brush on a brushcore on a spiral that I made as a reference. Is there a way to make it without creating 3 reference planes for each brush?
I am attaching the original brush that I made in SW (Børste 2 spiral) and the one I am trying to make now (Børste 3) in Inventor.
This is the brush that I made in SW that I want to remake in Inventor with different dimensions (same core diameter, total diameter 100mm, lenght 300mm)
I want to have brushes across the whole lenght of brushcore on the reference helix that I made
Solved by -niels-. Go to Solution.
I'm on IV2021 so i couldn't see what you did, but is there a reason why you're not using a rectangular pattern?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
Hey,
Thanks for the reply. I didnt think that rectangular pattern would be applicable in this case.
This works well, thank you!
Hey,
