3D Sketch Split Sketch disappearing when extrusion suppressed
- Mute
- Permalink
- Report
I have a model of a cylinder I am creating to turn it into (4) separate parts so that way I can print them and then assemble them with guides. I have these oval parts in the 3d sketches that have been projected to the surface, and then I split them all the way through and in some instances I used "thicken" to narrow them, or not at all for where i needed them.
You can see that the parts are there and separate; and it looks good; however, when I suppress the extrusion i get the following:
You see where the yellow parts are cut in half and the extrusions that should be on the other half of that are not existing. What am I missing; or should I be using something other than "split" and thicken?
