Message 1 of 11
3D Sketch Constraints - Baffled
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Having recently switched from 2020 to 2024, I've tried to create a 3D sketch & something is different.
In 2020, I'd draw lines, starting at the centre point, using precise input coordinates. Attached is an example created in 2020. The first line drawn is constrained, the rest aren't until they are dimensioned.
If I repeat the same procedure in 2024, the first line isn't constrained & neither are the rest, even after dimensioning.
To fully constrain, I have to apply constrain to axis. Attached is an example created in 2024.
The 2020 files behaves as expected when opened in 2024.
It's probably something really simple, so what have I missed?
