Hi, I am super new and only a student and pretty much have no idea what I'm doing xD I attempted to download and install Inventor Professional from this website, but I got the message saying "32 bit installer required" and it states that I have a 32 bit operating system. If it helps, I have a windows 7... What do I do?
Solved by mdavis22569. Go to Solution.
Solved by JDMather. Go to Solution.
What version of Inventor are you trying to install?
@cyan_fire wrote:
... but I got the message saying "32 bit installer required" and it states that I have a 32 bit operating system. ..?
How old is your computer?
It must be a very very old computer if it has a 32-bit OS.
Inventor 2015 was the last version that ran on 32-bit OS, so that is what you need to download.
You can get it from the Autodesk Student Community or from the Autodesk Virtual Agent.
You will need to get your student Serial Number for 2015 from the Student Community.
If your school is using a later release (which it should be as Inventor is free to schools) - you will not be able to open files created at school in later release in your 2015 release. But you can go from 2015 to later.
Install with UAC and anti-virus temporarily disabled.
I recommend running for at least a couple of weeks in 30-day Trial mode before Activating your free student license.
After installation, also download the Service Packs and Updates.
But let's take this step-by-step.
Go to your System Properties and verify that you are in fact running 32-bit version of Windows 7.
Verify that you have in fact downloaded the 32-bit installer for Inventor.
as far as what?
system requirements for inventor are here: https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Inventor 2015 was the last 32 bit version you need to look at upgrding to 64 bit
DarrenP
as far as what?
DarrenP
@Anonymous wrote:
same problem over here also
You have provided even less information than the OP?
From post #3 in this thread -
Can you ask your instructor to help you answer these questions?
1. How old is your computer?
2. What version of Windows Operating System are you using (show image if System Properties)?
3. What version of Inventor are you attempting to install?
Go to AVA and request it
Ava.autodesk.com
another page
https://knowledge.autodesk.com/contact-support/downloads-upgrades
Ava.autodesk.com
another page
32 bit installer download
@Anonymous wrote:32 bit installer download
Do you have a question?
What version of Inventor?
Hello, I want to download a 32-bit version
Hi Mouaad, if JDs accepted solution doesn't work for you them I'm afraid there is no way to get a 32 bit version. We haven't supported 32bit for a very long time.
