Hi @Anonymous,
I whipped this together quickly - I can make a screencast later.
I swept the outer edge as a semi-circle then made a midpoint plane to create the horizontal bars. I extruded a circle (2mm) using the 'To' extents, I just mirrored that bar and then used the rectangle pattern set to adjust to repeat the bars down.
The vertical bars use a similar process except the endpoint is created by projecting the outer round edge of the semi-circle and extruding as a surface. Then created a plane along the straight edge and sketched a circle, extruded using the the 'To Next' extents selecting the extruded surface. Finally, you can rectangle pattern using the adjust compute
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
