06:03 AM
Hi All,
Is there a way to change the drawing template so that the precision of alternative units doesn't cause the equivalent to be rounded up?
I have a part where it's thickness is modelled at 1.59mm (=1/16th inch). However, as the precision is set to 1/8th inch by default, the dimension shows 1.59mm equating to 1/8th inch which is incorrect.
Thank you,
Dan
Link copied
