256 Character Limit File Path Issue
jcharronYJF55
Message 1 of 21
jcharronYJF55
When trying to save in Inventor for eg. Frame Generator parts, I get the error "The System cannot find the file specified -> the Database in c:\[258 characters] could not be saved" or I get the error at Frame Generation where the filepath just glares red at me.
I have already edited the windows registry though to turn on the flag for LongPathsEnabled, which is what documentation has been steering me toward on this issue.
This is Windows 11 Pro.
I don't really know how to proceed.
I would go about restructuring my folder and file tree where I have all my files, but I already have enough files where this would cause me a significant amount of time and headache (days, and multiple tylenol) to move and restructure everything while keeping/breaking file/drawing/assembly dependencies intact (I have had bad experiences thus far with Pack and Go as well). A shame really, the first 91 or so chars are out of my control, it's just how we're set up in our collaboration space (C:\users\...\ACCDocs\...), and the rest if I don't use enough descriptors things *will* get lost and I don't want to resort to some wonky internal hexadecimal system where I have to know my project TK421 from project QZX989 just to save on characters. And the Frame generator itself wants 30 chars just for the frame .ipt itself, + "\Frame\", and X+2 chars for a subfolder it names based off the name of the assembly file it's being designed into. So I only have about 100 chars to handle my own folder tree and name my project files, which is becoming a bit of a hangup.
Replies (20)
Message 2 of 21
bradeneuropeArthur
Seems that you have done this already, right?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-Windows-10-def...
https://outsourcedit.co.nz/fixing-the-256-character-file-name-limit-in-windows-10-11/#:~:text=Go%20t....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 21
jcharronYJF55
Yes, I have done that:
And the file path is based on my C:\ drive though it is what ACC Docs has to sync to. Don't know if relevant but mention to be sure.
Message 4 of 21
johnsonshiue
Hi! Even though Long File Path is enabled in Windows, I don't think Inventor supports it. You need to limit the file path, including the file name to be less than 256 characters.
Many thanks!
Software Test Engineer
Message 5 of 21
jcharronYJF55
That is not what Autodesk's own documentation says,
"Autodesk products do not have their own internal path length limits and are only limited by the limits of the Windows operating system."
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/What-is-the-maximu...
Message 6 of 21
jcharronYJF55
I guess my recourse right now is we abbreviate the folder tree and tell my colleagues to reopen their .ipj files from explorer to restore their projects in their 'new' file paths. I'd still like to know that this is resolvable though because frame tool loves making its own subfolders and verbose part names.
Message 7 of 21
Mario.VanWiechen
Dont let it, I put the frame members in the same directory as the rest of my parts with short filenames. No BS directories and filenames
Do the work on the front end so you do not have issues like you have now
Learn to use the "File Naming Default " window
This is what my frame member directory looks like, you could add a minor desciption if it suited you
Message 8 of 21
jcharronYJF55
Where do I pull up this menu of options? Thanks
Message 9 of 21
Mario.VanWiechen
Message 10 of 21
bradeneuropeArthur
Find it here:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 21
jcharronYJF55
Excellent
Message 12 of 21
johnsonshiue
Hi! The article you mentioned is a bit confusing. Essentially, it says Windows dictates the path length. Inventor isn't capable of processing file name longer than 256 regardless of Windows' limitation.
Many thanks!
Message 13 of 21
k.hendrickx
Hi, I also just ran into this issue trying to have a nice folder structure for assembly and sub-assembly storage and came across what might be a sufficient workaround.
Apparently Inventor seems (as far as I have tested it) to handle shortcuts to folders quite well.
This means that you could place a shortcut to a folder that isn't as deep in your folder, and Inventor will redirect to this folder instead.
It seems to be working for assemblies (even existing ones); I haven't tried it yet with drawings or other linked documents though, so please test it for yourself before overhauling your folder structure using these shortcuts, but still worth mentioning, I guess.
wkr
Message 14 of 21
lewisanna2025
Community Visitor
Community Visitor
Yes, you can use Long Path Tool to solve this issue. Here's how:
  1. Download Long Path Tool from
  2. Install and open the software.
  3. Use the tool to:
    • Delete files/folders with long paths.
    • Move or copy data from deep directories.
    • Rename nested folders to shorter names.
Message 15 of 21
johnsonshiue
Hi Lewis,
It may appear working. But Inventor does not support file path longer than 256 characters internally.
Many thanks!
Message 16 of 21
charlotjohanson8954
Observer
Observer
You can use tools like Gs Richcopy 360 or Goodaync to copy or move long path name files without having to shortening every file name
Message 17 of 21
bomblotus03
Community Visitor
Community Visitor
You can try using a tool like LongPathTool. It helps manage and delete files or folders with long path issues easily.
Message 18 of 21
mdsaifulsim99
Community Visitor
Community Visitor
LongPathTool helps handle long file paths that hit the character limit in this issue.
Message 19 of 21
perry75857
Community Visitor
Community Visitor
try LongPathTool.
Message 20 of 21
perry75857
Community Visitor
Community Visitor
try Long Path Tool.
