Sounds as if the project you are currently using does not have the same location for Content Center parts as the project under which your design was created. Content Center part location is determined by the active project file (.ipj), which can either specify the folder explicitly, or simply default to the folder named in Application Options.
In addition, the active project also defines which Content Libraries are available to it. My guess is that you're not using the same project that you used to create this model, so your Content Center stuff is not connected. Either change to the correct .ipj file or edit your current one to connect to the correct CC libraries and parts.
Sam B
Inventor Pro 2026.1.1 | Windows 11 Home 24H2
