Creating xyz point
Creating xyz point
jeremy_camper
Message 1 of 12
Creating xyz point
jeremy_camper
Is there a way to manually enter a xyz point similar to nx?
Ref attached screen shot
Replies (11)
Message 2 of 12
JDMather
@jeremy_camper
Activate the Precise Input tool to enter xyz points directly.
You can also set Inventor to automatically enter Bends for you in a 3D path.
You can also do this directly from an Excel spreadsheet.
Message 3 of 12
kacper.suchomski
Hi
You didn't attach a screenshot.
What point do you mean? Do you mean the sketch point or the working point?
Kacper Suchomski
Message 4 of 12
jeremy_camper
Sorry about that
It's a screen shot from NX but want to try to do the same thing in inventor
Message 6 of 12
jeremy_camper
Precise input will let me manually enter it this way... Want to keep it simple as possible for what I'm doing
https://www.google.com/imgres?imgurl=https%3A%2F%2Fcommunity.sw.siemens.com%2Fsfc%2Fservlet.shepherd...
Message 7 of 12
kacper.suchomski
You still haven't answered the question - what type of point do you want to create?
Kacper Suchomski
Message 8 of 12
jeremy_camper
Guess you would call a inferred point a construction point
Message 9 of 12
JDMather
@kacper.suchomski
Apparently attempting to do a tube/pipe route.
@jeremy_camper
In addition to Precise Input or spread sheet import, there is also an entire work environment (Routed Systems) dedicated for this in Autodesk Inventor Professional.
Message 10 of 12
kacper.suchomski
https://help.autodesk.com/view/INVNTOR/2026/ENU/?guid=GUID-38A9748E-FA2D-44D3-928C-DFE1326A9385
Kacper Suchomski
Message 11 of 12
jeremy_camper
Will this let me create a non-assoctive point?
I just want it to be a manual construction point in space
Point. Creates a construction point
Message 12 of 12
kacper.suchomski
Did you read the help file I provided?
Kacper Suchomski
