Help with dynamic simulation
dinhhieuDEHZB
dinhhieuDEHZB
Hi all! I'm stuck on trying to make the second segment of this photo here to rotate. I've constrained the two to the same plane but am not sure on how I'd add torque to the second joint to move.
I'm looking to add a couple more segments after the 2nd one and have each of them rotate abit making a wiggle motion. TIA!
CCarreiras
Hi!
It should be easy. Probably there's already one constraint prevent the motion.
Can you share the file?
CCarreiras
