Inventor Forum
Welcome to Autodeskā€™s Inventor Forums. Share your knowledge, ask questions, and explore popular Inventor topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
2014 Create DWF of ipn
3 REPLIES 3
285 Views, 3 Replies
In the Publish Presentation box, Presentations tab, Options, Instructions.
Questions:
Am I able to create and include text instructions in the tweaked file to go along with the animation?
How is this accomplished in the ipn?
J.
3 REPLIES 3
jhackney1972
Adding instructions that appear at the bottom of the screen during the playback of a DWF in Design Review was possible in older versions of Inventor.  This feature was removed when they changed the presentation environment, I am not sure what version but in the two versions I have access to 2017 and 2018 do not have this ability.  I am pretty sure 2014 still has this ability.
I went online and found a YouTube video from Inventor 2012 that had screenshots I needed to show you where to place the instructions.  This is done per sequence under the presentation Tasks.  In Image 1, I captured the Task and Sequence view.  In Image 2 I captured the dialog box resulting from right clicking and editing a sequence.  You would place your instruction text in the lower Description Field for each sequence you desire.
When you do export the presentation, be sure and select the check box for the instructions shown in your graphic.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
S_May
in reply to: jhackney1972
Thanks, we'll be upgrading versions in the near future, too bad this was removed.
