Inventor Forum
Push update exported derivated parameters
3 REPLIES 3
admaiora
285 Views, 3 Replies
Di you, or some of you, have a similar issue?
(file 0) Skeleton with exported and Custom Formatted parameters
(file 1) Derived part with these parameters
(file2) Derived part with these parameters from file 1
In some cases we have lost the custom formatting.
Any idea?
Thanks!
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
3 REPLIES 3
johnsonshiue
in reply to: admaiora
Hi Admaiora,
Yes, I have seen this issue before. There are multiple ways to format a custom parameter. Sometimes, it can lead to non-intuitive behavior. If the custom parameter will be referenced in the drawing, I would try to override the unit or format in drawing. Or, you would have the desirable unit in the parameter in the part to begin with.
If you still see the behavior, please show me an example.
Many thanks!
Software Test Engineer
admaiora
in reply to: johnsonshiue
Thank you @johnsonshiue !
Always nice!
Admaiora
jtylerbc
I've seen the format loss even when it wasn't being derived twice.  This has popped up a couple of times recently for me on different projects (Inv 2016).
  1. Skeleton Part (whether there is Custom Format on parameters doesn't make a difference)
  2. Part 1 - includes parameters derived from Skeleton
  3. Set parameter as Exported in Part 1 and add Custom Format.  Everything looks correct initially.
  4. Value of parameter gets changed in Skeleton.  Custom Format of the parameter in Skeleton is still correct, but in Part 1 it is lost.
It happened multiple times on files from at least two projects.  In one, I just created extra User Parameters in Part 1 and set them equal to the derived parameters.  The additional parameters don't lose their Custom Format settings.  On the other, I was already using a heavily customized parts list format to create a dimension summary table for a series of available sizes, so I just applied my formatting at the parts list level.
I've been able to work around it, but it's rather annoying.
