Tooltip on button
Tooltip on button
Message 1 of 18
Tooltip on button
Is it possible to add a tooltip to a custom button (macro button).
Default seems to be the "sub name" as tooltip.
Lars Andersson
Replies (17)
Message 2 of 18
This is not currently possible.
-Brian
"Lars Andersson" wrote in message
news:1896AF73781188D534045BB96768F06B@in.WebX.maYIadrTaRb...
> Lars Andersson
Message 3 of 18
A bit of clarification. It is not currently possible to define a tooltip
for a button created for a VBA macro. If you create buttons through an
Add-In for your own commands you can define the tool tip and the description
text that displays at the bottom of the Inventor window.
-Brian
"Brian Ekins (Autodesk)" wrote in message
news:...
> -Brian
> > Lars Andersson
Message 4 of 18
Brian,
Do you think or know that it will be possible in the future?
Lars
"Brian Ekins (Autodesk)" skrev i meddelandet
news:3F4A5BBF287AA289331382E91BEEDE24@in.WebX.maYIadrTaRb...
description
> -Brian
> news:...
> > -Brian
> > > Lars Andersson
Message 5 of 18
I don't know. This is really an Inventor user interface issue rather than
an API issue so I'm not directly involved in the planning.
-Brian
news:F0D01E33C6B6FDC4103FB5889F1FAE6D@in.WebX.maYIadrTaRb...
> Brian,
> Lars
tooltip
> description
> > -Brian
> > news:...
> > > -Brian
> > > > Lars Andersson
Message 6 of 18
miechh
I was asking myself the same question, but it seems that seven and a half years later still nothing has changed; can't change the tooltiptext for my macro's. I know, we all want to sit in the front row for just a dime (dutch expression Smiley Very Happy), but it would be so cool to also have your own tool-tip-text present for custom macro's/buttons. In AutoCAD you can add macro's to a custom button on a custom toolbar AND create tool-tip-texts for that button. So why can't this be made possible for Inventor.
Product Design Suite 2024
Inventor 2024 (v 28.20.27200.0000), Vault Basic 2024
Fusion 360
HP Workstation Z4
Intel Xeon 3.4GHz
32GB RAM
Windows 10 Professional (64bit)
Message 7 of 18
Another 7 years later (13 years in total!)
Still not possible I believe?
Would be very cool indeed!
Message 8 of 18
weiser
Some people are arriving later than the other ....
I did not find a way to get a tooltop for custom button in Inventor 2019 too?
Or do I missed somehing?
Message 9 of 18
bradeneuropeArthur
Could you give me the name of the macrobutton?
I prepared something that seems to work here.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 10 of 18
AlexFielder
In lieu of @bradeneuropeArthur replying with a working solution, for background, you can use the "ProgressiveTooltip" property of a button to create a fly-out image like this:
Based on the following:
button1 = new InventorButton(buttonPlugin.Path, buttonPlugin.ButtonDisplayName, buttonPlugin.ButtonInternalName, buttonPlugin.Description, buttonPlugin.ToolTip, icon1, icon1, buttonPlugin.ProgressiveToolTipImagePath, CommandTypesEnum.kShapeEditCmdType, ButtonDisplayEnum.kDisplayTextInLearningMode);
button1.ButtonDef.ProgressiveToolTip.Description = buttonPlugin.ProgressiveToolTipDescription;
button1.ButtonDef.ProgressiveToolTip.ExpandedDescription = buttonPlugin.ProgressiveToolTipExpandedDescription;
button1.ButtonDef.ProgressiveToolTip.IsProgressive = true;
button1.ButtonDef.ProgressiveToolTip.Title = buttonPlugin.ProgressiveToolTipTitle;
I don't have an example I can share that makes it any simpler than ^.
Message 11 of 18
weiser
the macro I want to describe is named "Mxx" from the module "Bemaßung".
looking forward to your answer!
Thanks in advance
Message 12 of 18
weiser
Hi Alex,
I've red the article about the progressive tooltip but didn't understand where to put the code.....
So may be you can help me out with an tutorial for newbies....
Thans in advance
Message 13 of 18
bradeneuropeArthur
I have figured it out.
Please send me a private message as reminder.
I will upload the code. I am far from my desk right now.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 18
bradeneuropeArthur
With this code you can:
Add macro button to the ribbon.
Add a tooltip with text and image.
run VBA macros with your code set.
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As Ribbon
Set b = a.UserInterfaceManager.Ribbons.Item(2) ' "Part"
Dim c As RibbonTab
Set c = b.RibbonTabs.Item(2) ' "id_TabFlatPattern"
Dim rp As RibbonPanel
Set rp = c.RibbonPanels.Item(1) ' "id_PanelP_Model2DSketchCreate"
Dim bu As ButtonDefinition
Dim MCD As MacroControlDefinition
Dim cd As ControlDefinition
Set MCD = a.CommandManager.ControlDefinitions.AddMacroControlDefinition("YourModuleName.YourRoutineName2") ' For Example Module1.Main
MCD.ProgressiveToolTip.ExpandedDescription = "This could be your additional description...."
MCD.ProgressiveToolTip.Image = "C:\Files\YourImage.jpg"
rp.CommandControls.AddMacro MCD, False
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 15 of 18
bradeneuropeArthur
With this code you can add additional:
  • Tooltips
  • images
  • expanded descriptions
To existing VBA commands that have been added by the user.
You need to know the name of the macro of course.
Public Sub main()
Dim MCDDefaultUser As MacroControlDefinition
Set MCDDefaultUser = a.CommandManager.ControlDefinitions.Item("Macro:YourModuleName.YourRoutineName2")
MCDDefaultUser.ProgressiveToolTip.ExpandedDescription = "This could be your additional description...."
MCDDefaultUser.ProgressiveToolTip.Image = "C:\Files\YourImage.jpg"
End Sub
You need to create a button to load this code everytime you start inventor, because vba is not started with inventor.
Or you could use an add in to load run this code, which is the better way I think.
Please let me know if you need help regarding this.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 18
bradeneuropeArthur
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 17 of 18
weiser
Hi there,
can anybody mark Arthur's answer as a solution.... because I can't do it ... aybe I have to be the one to upen up the thread?!
Regards & thanks again to Arthur!
Message 18 of 18
Maxim-CADman77
@AlexFielder
What about multi-lingval (progressive) tooltips?
Should I use Select Case?
Please vote for Inventor-Idea Text Search within Option Names
