scaling functionality for a set of drawing views
GeorgK
Advisor Advisor
Message 1 of 18
GeorgK
Hello together,
there are some posts to solve this. Does there exist a better solution in Inventor 2019 to calculate the view scale for a set of drawing views depending from the sheet size? All views (front, bottom, top etc.) should fit on the sheet with the correct scale (1:1, 1:2 ...) or do I have to calculate it the old way? Does there exist a universal solution?
https://forums.autodesk.com/t5/inventor-customization/ilogic-coding-to-create-automated-drawing/m-p/...
https://forums.autodesk.com/t5/inventor-customization/help-with-ilogic-to-create-automated-2d-drawin...
https://forums.autodesk.com/t5/inventor-customization/ilogic-auto-create-scaled-drawing-from-a-model...
https://forums.autodesk.com/t5/inventor-customization/scaling-views-to-fit-a-sheet/td-p/2171712
Thank you
Georg
Replies (17)
Message 2 of 18
MechMachineMan
Don't think so. You can use those algorithms or create your own. It really depends on what you want the drawing to look like.
Do you want the view to take up the full page but be 1 to 1?
Do you want the view to be roughly 1/3 of the page area?
Do you want the view to be 1/3 of the page height, but no wider than 1/2 the page width?
etc., etc.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 18
GeorgK
The user could choose in the assembly the hole assembly or select a part. In part environment the front fiew is selected. The front view is the base view in the sheet. I thought about calculating the dimensions (bounding box http://modthemachine.typepad.com/my_weblog/2017/06/getting-the-overall-size-of-parts.html , https://forums.autodesk.com/t5/inventor-customization/calculate-limits-max-and-min-assemblies-files/...) from the part or assembly from the front view. That saves a lot of drawing changes and calculations.
The user should choose between the different sheet sizes, styles (hidden, without hidden lines, shaded) and the following views:
The views together should be 3/4 of the sheet size. The rest space is for the dimensions. After the sheet is generated the user should have the option to scale the views up or down or to change another sheet size (Portrait: A4; landscape: A3, A2, A1, A0).
The views should be automaticaly scaled to 1:1, 1:2, 1:2,5 , 1:5, 1:10, 2:1, 2,5:1,  5:1, 10:1) If the size of the views is too big to fit on the sheet the next sheet size should be choosen.
What do you thing is the best and fastest way to do the calculations?
Message 4 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Nice workflow to automate genaration of drawing views in Drawing document. In this, Sheet space(3/4), Sheet Size, styles and Drawing view orientations are fixed. Now, view scale and bounding box of model will varies from model to model.
I think that appropriate way to address this would be considering ranges of bounding box of model. For different view scale, there will be different ranges of bounding box.
For Example,
Sheet size Drawing orientation  Scale  Bounding box range (in cm)
A4 First type with 5 views 1:1 (x = 10, y = 10) to (x = 15, y = 15)
    1:2 (x = 15, y = 15) to (x = 20, y = 20)
    1:2.5 (x = 20, y = 20) to (x = 25, y = 25)
    1:5 (x = 25, y = 25) to (x = 35, y = 35)
    1:10 (x = 35, y = 35) to (x = 50, y = 50)
Similarly, Bounding box range can be fixed based on sheet size and view scale.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 5 of 18
GeorgK
Hello @chandra.shekar.g,
that's a good idea. But how to code this?
Thank you Georg
Message 6 of 18
GeorgK
As a start:
Dim m_inventorApp As Inventor.Application = Nothing
            m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
            Dim oDrawingDoc As DrawingDocument
            oDrawingDoc = m_inventorApp.ActiveDocument
            Dim oTG As TransientGeometry = m_inventorApp.TransientGeometry
            Dim oTrans As Transaction
            oTrans = m_inventorApp.TransactionManager.StartTransaction(m_inventorApp.ActiveDocument, "Ansichten verschieben")
            Dim ActiveSheet As Sheet
            ActiveSheet = oDrawingDoc.ActiveSheet
            Dim oView As DrawingView
            Dim oSheet As Sheet
            oSheet = oDrawingDoc.ActiveSheet
            Dim oListx As ArrayList = New ArrayList()
            Dim oListy As ArrayList = New ArrayList()
            For Each oView In oSheet.DrawingViews
                oListx.Add(oView.Position.X)
                oListy.Add(oView.Position.Y)
            Next
            oListx.Sort()
            oListy.Sort()
            Dim mid As Integer
            mid = (oListy.Count - 1) / 2
            Dim midView As DrawingView = Nothing
                If Math.Round(oView.Position.X, 6) = Math.Round(oListx(mid), 6) And Math.Round(oView.Position.Y, 6) = Math.Round(oListy(mid), 6) Then
                    midView = oView
                    'MsgBox(midView.Name.ToString)
                    Exit For
            Next
            Dim oPositionX As Double
            Dim oPositionY As Double
            Dim oBaseViewHeight As Double
            Dim oBaseViewWidth As Double
            Dim prompt As String = "Bitte geben Sie den Abstand ein"
            Dim title As String = "Abstand zur " & midView.Name
            Dim oAbstand As String
            ' Set prompt.
            prompt = "Bitte geben Sie den Abstand ein"
            ' Set title.
            title = "Abstand zur " & midView.Name & " in mm"
            ' Set default value.
            oAbstand = "80"
            ' Display prompt, title, and default value.
            oAbstand = Interaction.InputBox(prompt, title, oAbstand)
            If oAbstand = "" Then
                Exit Sub
            'Prüfen, ob Zahlen
            If oAbstand.All(AddressOf Char.IsDigit) = True Then
                oAbstand = oAbstand / 10
            Else
                Exit Sub
            For Each oView In ActiveSheet.DrawingViews
                'If oView.ViewType = Inventor.DrawingViewTypeEnum.kStandardDrawingViewType Then
                If oView.Name = midView.Name Then
                    oPositionX = oView.Position.X
                    oPositionY = oView.Position.Y
                    oBaseViewHeight = oView.Height
                    oBaseViewWidth = oView.Width
                    'MsgBox("Height: " & oBaseViewHeight & " ; " & "Width:" & oBaseViewWidth)
                'End If
                If oView.Position.X > oPositionX And oView.Position.Y = oPositionY Then
                    ' MsgBox("Ansicht rechts")
                    'Ansicht rechts
                    Dim oRightViewPosition As Point2d
                    oRightViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d()
                    oRightViewPosition.X = oPositionX + (oBaseViewWidth) + oView.Height / 2 + oAbstand
                    oRightViewPosition.Y = oPositionY
                    oView.Position = oRightViewPosition
                If oView.Position.X < oPositionX And oView.Position.Y = oPositionY Then
                    ' MsgBox("Ansicht links")
                    'Ansicht links
                    oRightViewPosition.X = oPositionX - (oBaseViewWidth) - oView.Height / 2 - oAbstand
                If oView.Position.X = oPositionX And oView.Position.Y < oPositionY Then
                    ' MsgBox("Ansicht unten")
                    'Ansicht unten
                    oRightViewPosition.Y = oPositionY - oBaseViewHeight - oView.Height / 2 - oAbstand
But this works only if there is one projected view per side (left, right ..). Does someone have an idea to fix this?
Message 7 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Are you generating drawing views from start?
Hoping that below calculation would help in sizing drawing views.
pTmax = ModelDocument.Componentdefintion.RangeBox.MaxPoint
pTmin = ModelDocument.ComponentDefinition.RangeBox.MinPoint
X = pTmax.X - pTmin.X
Y = pTmax.Y - pTmin.Y
Z = pTmax.Z - pTmin.Z
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 18
GeorgK
I am generating drawing views from start and change them after they are finished.
The main problem is if there are more projected views or section views to one side. Do you have an idea to solve this?
Message 9 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Can you please provide existing source code and sample part/assembly to automate drawing generation? I will try to feasible solution. On the other hand, bounding box of projected view and section view may not be accurate.
Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 18
GeorgK
I have several programs do solve this. One for existing drawings and one for new drawings. The Problem is to sort the views and distances to fit on a sheet and that the views don't overlap (ISO views).
Dim oSheet As Sheet
Next
oListx.Sort()
oListy.Sort()
Dim mid As Integer
		midView = oView
		Exit For
Next
' Set prompt.
' Set title.
oAbstand = "80"
	Exit Sub
'Prüfen, ob Zahlen
Else
	Exit Sub
	'End If
	Dim oScale As Double
		'Ansicht rechts
		If oView.Scale >= 1 Then
			oScale = oView.Scale
		If oView.Scale < 1 Then
			oScale = 1 / oView.Scale
		oRightViewPosition.X = oPositionX + (oBaseViewWidth) + (oView.Height / 2) + oAbstand * oScale
		'Ansicht links
		oRightViewPosition.X = oPositionX - (oBaseViewWidth) - (oView.Height / 2) - oAbstand * oScale
		'Ansicht unten
		oRightViewPosition.Y = oPositionY - oBaseViewHeight - (oView.Height / 2) - oAbstand * oScale
	If oView.Position.X = oPositionX And oView.Position.Y > oPositionY Then
		' MsgBox("Ansicht oben")
		'Ansicht oben
		oRightViewPosition.Y = oPositionY + oBaseViewHeight + (oView.Height / 2) + oAbstand * oScale
	If oView.Position.X > oPositionX And oView.Position.Y > oPositionY Then
		' MsgBox("Ansicht ISO rechs oben")
		'Ansicht ISO rechs oben
	If oView.Position.X < oPositionX And oView.Position.Y > oPositionY Then
		' MsgBox("Ansicht ISO links oben")
		'Ansicht ISO links oben
	If oView.Position.X > oPositionX And oView.Position.Y < oPositionY Then
		' MsgBox("Ansicht ISO rechs unten")
		'Ansicht ISO rechs unten
	If oView.Position.X < oPositionX And oView.Position.Y < oPositionY Then
		' MsgBox("Ansicht ISO links unten")
		'Ansicht ISO links unten
Next
oTrans.End()
m_inventorApp.ActiveView.Fit()
The code is working for the yellow marked area, 4 and 5. Not for 1, 2 and 3.
        Dim oIamDoc As AssemblyDocument
        oIamDoc = m_inventorApp.ActiveDocument
        Dim oCompOcc As ComponentOccurrence
        oCompOcc = m_inventorApp.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Bitte wählen Sie ein Bauteil oder eine Unterbaugruppe")
        If IsNothing(oCompOcc) Then
            Exit Sub
        Dim oPart As PartDocument
        oPart = oCompOcc.Definition.Document
        ' Create a new drawing document.
        Dim oDoc As DrawingDocument
        'oDoc = m_inventorApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, m_inventorApp.FileManager.GetTemplateFile(DocumentTypeEnum.kDrawingDocumentObject))
        oDoc = m_inventorApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2017\Templates\Norm.idw", True)
        m_inventorApp.SilentOperation = True
        Dim oSheet As Sheet = oDrawingDoc.ActiveSheet
        m_inventorApp.ActiveDocument.ActiveSheet.Orientation = PageOrientationTypeEnum.kLandscapePageOrientation
        Select Case True
            Case RadioButton_A4.Checked
                oSheet.Size = DrawingSheetSizeEnum.kA4DrawingSheetSize
            Case RadioButton_A3.Checked
                oSheet.Size = DrawingSheetSizeEnum.kA3DrawingSheetSize
            Case RadioButton_A2.Checked
                oSheet.Size = DrawingSheetSizeEnum.kA2DrawingSheetSize
            Case RadioButton_A1.Checked
                oSheet.Size = DrawingSheetSizeEnum.kA1DrawingSheetSize
            Case RadioButton_A0.Checked
                oSheet.Size = DrawingSheetSizeEnum.kA0DrawingSheetSize
        End Select
        Dim oFrontViewX As Integer = oSheet.Width / 2 '17
        Dim oFrontViewY As Integer = oSheet.Height / 2 + 1 '13
        Dim oFrontViewScale As Integer = 1
        ' Create the base view.
        Dim oBaseView As DrawingView
        Select Case True
            Case RadioBtn_Verdeckt.Checked
                oBaseView = oSheet.DrawingViews.AddBaseView(oPart, oTG.CreatePoint2d(oFrontViewX, oFrontViewY), oFrontViewScale, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle) 'Hauptansicht
                ' Create projected views.
                Dim oDownView As DrawingView
                oDownView = oSheet.DrawingViews.AddProjectedView(oBaseView, oTG.CreatePoint2d(oFrontViewX, oFrontViewY - 5), DrawingViewStyleEnum.kFromBaseDrawingViewStyle) 'Unten
                Dim oRightView As DrawingView
                oRightView = oSheet.DrawingViews.AddProjectedView(oBaseView, oTG.CreatePoint2d(oFrontViewX + 5, oFrontViewY), DrawingViewStyleEnum.kFromBaseDrawingViewStyle) 'Rechts
                Dim oLeftView As DrawingView
                oLeftView = oSheet.DrawingViews.AddProjectedView(oBaseView, oTG.CreatePoint2d(oFrontViewX - 5, oFrontViewY), DrawingViewStyleEnum.kFromBaseDrawingViewStyle) 'Links
                ' Create Top views.
                Dim oTopView As DrawingView
                oTopView = oSheet.DrawingViews.AddProjectedView(oBaseView, oTG.CreatePoint2d(oFrontViewX, oFrontViewY + 5), DrawingViewStyleEnum.kFromBaseDrawingViewStyle) 'Oben
                ' Create ISO views.
                Dim oIsoView As DrawingView
                oIsoView = oSheet.DrawingViews.AddProjectedView(oBaseView, oTG.CreatePoint2d(oFrontViewX - 9, oFrontViewY + 8), DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle) ' ISO links oben
                '###### Rechts #########
                ' Create a new point to move the baseview to.
                oRightViewPosition.X = oFrontViewX + (oBaseView.Width / 2) + 3
                oRightViewPosition.Y = oFrontViewY
                'Move the Rightview to the new position
                oRightView.Position = oRightViewPosition
                '/###### Rechts #########
                '###### Links #########
                Dim oLeftViewPosition As Point2d
                oLeftViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d()
                oLeftViewPosition.X = oFrontViewX - (oBaseView.Width / 2) - 3
                oLeftViewPosition.Y = oFrontViewY
                'Move the LeftView to the new position
                oLeftView.Position = oLeftViewPosition
                '/###### Links #########
                '###### Oben #########
                Dim oTopViewPosition As Point2d
                oTopViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d()
                oTopViewPosition.X = oFrontViewX
                oTopViewPosition.Y = oFrontViewY + (oBaseView.Height / 2) + 3
                'Move the TopView to the new position
                oTopView.Position = oTopViewPosition
                '/###### Oben #########
                '###### Unten #########
                Dim oDownViewPosition As Point2d
                oDownViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d()
                oDownViewPosition.X = oFrontViewX
                oDownViewPosition.Y = oFrontViewY - (oBaseView.Height / 2) - 3
                'Move the DownView to the new position
                oDownView.Position = oDownViewPosition
        '/###### Unten #########
            Case RadioBtn_OhneVerdeckte.Checked
                oBaseView = oSheet.DrawingViews.AddBaseView(oPart, oTG.CreatePoint2d(oFrontViewX, oFrontViewY), oFrontViewScale, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle) 'Hauptansicht
                ' Create Top views.
                ' Create ISO views.
            Case RadioBtn_Schattiert.Checked
                oBaseView = oSheet.DrawingViews.AddBaseView(oPart, oTG.CreatePoint2d(oFrontViewX, oFrontViewY), oFrontViewScale, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kShadedDrawingViewStyle) 'Hauptansicht
                ' Create Top views.
                ' Create ISO views.
        End Select
        'SetAutomatedCenterlineSettings
        Dim ViewCount As Integer
        Dim StartCount As Integer
        StartCount = 0
        'number of drawing views
        Dim oviews As DrawingViews
        ViewCount = m_inventorApp.ActiveDocument.ActiveSheet.DrawingViews.count
        'define collection of views objects
        oviews = m_inventorApp.ActiveDocument.ActiveSheet.DrawingViews
        ' Places Centerlines on all of the drawing views
        For StartCount = 1 To ViewCount
            oviews.Item(StartCount).SetAutomatedCenterlineSettings()
        Next
        oviews = oSheet.DrawingViews
        For Each oView In oviews
        Next
        m_inventorApp.SilentOperation = False
Dim mApp As Inventor.Application
        mApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
        oDoc = mApp.ActiveDocument
        Dim oSheet As Sheet
        oSheet = oDoc.ActiveSheet
        Next
        oListx.Sort()
        oListy.Sort()
        Dim mid As Integer
                midView = oView
                Exit For
        Next
        oDoc.SelectSet.Select(midView)
I think this should be added to Inventor. That would be a big time saver.  There is a similar case:
https://forums.autodesk.com/t5/inventor-customization/automatic-scale-and-view-position/td-p/5784680
Thank you very much.
Georg
Message 11 of 18
GeorgK
Message 12 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Generation of drawing seems working fine. But rearranging drawing views needs minor changes.
After changes, code seems to work for all drawing views. Check the same from your end and let me know result.
Private Sub ReArrange_Drawing()
Dim oDrawingDoc As DrawingDocument oDrawingDoc = m_inventorApp.ActiveDocument Dim oTG As TransientGeometry = m_inventorApp.TransientGeometry Dim oTrans As Transaction oTrans = m_inventorApp.TransactionManager.StartTransaction(m_inventorApp.ActiveDocument, "Ansichten verschieben") Dim ActiveSheet As Sheet ActiveSheet = oDrawingDoc.ActiveSheet Dim oView As DrawingView '########################### Dim oSheet As Sheet oSheet = oDrawingDoc.ActiveSheet Dim oListx As ArrayList = New ArrayList() Dim oListy As ArrayList = New ArrayList() For Each oView In oSheet.DrawingViews oListx.Add(oView.Position.X) oListy.Add(oView.Position.Y) Next oListx.Sort() oListy.Sort() Dim mid As Integer mid = (oListy.Count - 1) / 2 Dim midView As DrawingView = Nothing For Each oView In oSheet.DrawingViews If Math.Round(oView.Position.X, 6) = Math.Round(oListx(mid), 6) And Math.Round(oView.Position.Y, 6) = Math.Round(oListy(mid), 6) Then midView = oView 'MsgBox(midView.Name.ToString) Exit For End If Next '################################ Dim oPositionX As Double Dim oPositionY As Double Dim oBaseViewHeight As Double Dim oBaseViewWidth As Double Dim prompt As String = "Bitte geben Sie den Abstand ein" Dim title As String = "Abstand zur " & midView.Name Dim oAbstand As String ' Set prompt. prompt = "Bitte geben Sie den Abstand ein" ' Set title. title = "Abstand zur " & midView.Name & " in mm" ' Set default value. oAbstand = "80" ' Display prompt, title, and default value. oAbstand = Interaction.InputBox(prompt, title, oAbstand) If oAbstand = "" Then Exit Sub End If 'Prüfen, ob Zahlen If oAbstand.All(AddressOf Char.IsDigit) = True Then oAbstand = oAbstand / 10 Else Exit Sub End If For Each oView In ActiveSheet.DrawingViews 'If oView.ViewType = Inventor.DrawingViewTypeEnum.kStandardDrawingViewType Then If oView.Name = midView.Name Then oPositionX = oView.Position.X oPositionY = oView.Position.Y oBaseViewHeight = oView.Height oBaseViewWidth = oView.Width End If 'End If Dim xRange As Double Dim yRange As Double xRange = Math.Round(oView.Position.X, 2) - Math.Round(oPositionX, 2) yRange = Math.Round(oView.Position.Y, 2) - Math.Round(oPositionY, 2) Dim oScale As Double If oView.Position.X > oPositionX And Math.Round(yRange, 2) < 1 Then ' MsgBox("Ansicht rechts") 'Ansicht rechts If oView.Scale >= 1 Then oScale = oView.Scale End If If oView.Scale < 1 Then oScale = 1 / oView.Scale End If Dim oRightViewPosition As Point2d oRightViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d() oRightViewPosition.X = oView.Position.X + oAbstand oRightViewPosition.Y = oView.Position.Y oView.Position = oRightViewPosition ElseIf oView.Position.X < oPositionX And Math.Round(yRange, 2) < 1 Then ' MsgBox("Ansicht links") 'Ansicht links If oView.Scale >= 1 Then oScale = oView.Scale End If If oView.Scale < 1 Then oScale = 1 / oView.Scale End If Dim oRightViewPosition As Point2d oRightViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d() oRightViewPosition.X = oView.Position.X - oAbstand oRightViewPosition.Y = oView.Position.Y oView.Position = oRightViewPosition ElseIf Math.Round(xRange, 2) < 1 And oView.Position.Y < oPositionY Then ' MsgBox("Ansicht unten") 'Ansicht unten If oView.Scale >= 1 Then oScale = oView.Scale End If If oView.Scale < 1 Then oScale = 1 / oView.Scale End If Dim oRightViewPosition As Point2d oRightViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d() oRightViewPosition.X = oView.Position.X oRightViewPosition.Y = oView.Position.Y - (oAbstand) oView.Position = oRightViewPosition ElseIf Math.Round(xRange, 2) < 1 And oView.Position.Y > oPositionY Then ' MsgBox("Ansicht oben") 'Ansicht oben If oView.Scale >= 1 Then oScale = oView.Scale End If If oView.Scale < 1 Then oScale = 1 / oView.Scale End If Dim oRightViewPosition As Point2d oRightViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d() oRightViewPosition.X = oView.Position.X oRightViewPosition.Y = oView.Position.Y + (oAbstand) oView.Position = oRightViewPosition ElseIf oView.Position.X > oPositionX And oView.Position.Y > oPositionY Then ' MsgBox("Ansicht ISO rechs oben") 'Ansicht ISO rechs oben If oView.Scale >= 1 Then oScale = oView.Scale End If If oView.Scale < 1 Then oScale = 1 / oView.Scale End If Dim oRightViewPosition As Point2d oRightViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d() oRightViewPosition.X = oView.Position.X + (oAbstand) oRightViewPosition.Y = oView.Position.Y + (oAbstand) oView.Position = oRightViewPosition ElseIf oView.Position.X < oPositionX And oView.Position.Y > oPositionY Then ' MsgBox("Ansicht ISO links oben") 'Ansicht ISO links oben If oView.Scale >= 1 Then oScale = oView.Scale End If If oView.Scale < 1 Then oScale = 1 / oView.Scale End If Dim oRightViewPosition As Point2d oRightViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d() oRightViewPosition.X = oView.Position.X - (oAbstand) oRightViewPosition.Y = oView.Position.Y + (oAbstand) oView.Position = oRightViewPosition ElseIf oView.Position.X > oPositionX And oView.Position.Y < oPositionY Then ' MsgBox("Ansicht ISO rechs unten") 'Ansicht ISO rechs unten If oView.Scale >= 1 Then oScale = oView.Scale End If If oView.Scale < 1 Then oScale = 1 / oView.Scale End If Dim oRightViewPosition As Point2d oRightViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d() oRightViewPosition.X = oView.Position.X + (oAbstand) oRightViewPosition.Y = oView.Position.Y - (oAbstand) oView.Position = oRightViewPosition ElseIf oView.Position.X < oPositionX And oView.Position.Y < oPositionY Then ' MsgBox("Ansicht ISO links unten") 'Ansicht ISO links unten If oView.Scale >= 1 Then oScale = oView.Scale End If If oView.Scale < 1 Then oScale = 1 / oView.Scale End If Dim oRightViewPosition As Point2d oRightViewPosition = m_inventorApp.TransientGeometry.CreatePoint2d() oRightViewPosition.X = oView.Position.X - (oAbstand) oRightViewPosition.Y = oView.Position.Y - (oAbstand) oView.Position = oRightViewPosition End If Next oTrans.End() m_inventorApp.ActiveView.Fit() End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Like".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 13 of 18
GeorgK
Your code increases the distance between the views with each call. However, the distance should be as large as entered. In addition, the distance between the views should be equalized or equal. Therefore different regions / circles have to be defined. My code works for the inner circle. It does not work for the other circles.
Your code works fine, if only the distance should be increased and the arrangement should remain the same. But I need a function to increase or decrease the distance.
Views.pngThank you for your help
Georg
Message 14 of 18
HermJan.Otterman
verry nice!, but just to think things through... do you realy need the exact scale of f.e. 1:2 ...??
do you print these drawings 1 tot 1....? if not (what I see 99 of 100 times) the printed version will not be on scale..
so if the printed version is not on scale, you can use any scale in your drawing, and makes coding it easier...
it was just a thought.....
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Message 15 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
Decreasing distance between views is similar to Increasing distance. messagebox is created to read option either to increase or decrease distance. Below code would help to increase or decrease the same.
        Dim oSheet As Sheet
        Next
        oListx.Sort()
        oListy.Sort()
        Dim mid As Integer
                midView = oView
                Exit For
        Next
        ' Set prompt.
        ' Set title.
        oAbstand = "80"
            Exit Sub
        'Prüfen, ob Zahlen
        Else
            Exit Sub
        Dim oResult As DialogResult
        oResult = MessageBox.Show("Increasing(Yes) or Decreasing (No)", "Increasing/Decreasing", MessageBoxButtons.YesNo)
        If oResult = DialogResult.No Then
            oAbstand = oAbstand * (-1)
            'End If
                'Ansicht rechts
                'Ansicht links
                'Ansicht unten
                'Ansicht oben
        Next
        oTrans.End()
    End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 16 of 18
GeorgK
your code does not adjust the distance between each view. I did some tests with this code:
        Dim oSheet As Sheet
        Next
        oListx.Sort()
        oListy.Sort()
        Dim mid As Integer
                midView = oView
                Exit For
        Next
        ' Set prompt.
        ' Set title.
        oAbstand = "10"
            Exit Sub
        'Prüfen, ob Zahlen
        Else
            Exit Sub
        Dim valuesRE As New List(Of Tuple(Of String, Double, Double, Double, Double)) 'Name, x-Wert, Y-Wert, Breite, Höhe
        Dim valuesLI As New List(Of Tuple(Of String, Double, Double, Double, Double))
        Dim valuesU As New List(Of Tuple(Of String, Double, Double, Double, Double))
        Dim valuesO As New List(Of Tuple(Of String, Double, Double, Double, Double))
        Dim values_ISO_Re_O As New List(Of Tuple(Of String, Double, Double, Double, Double))
        Dim values_ISO_Li_O As New List(Of Tuple(Of String, Double, Double, Double, Double))
        Dim values_ISO_Re_U As New List(Of Tuple(Of String, Double, Double, Double, Double))
        Dim values_ISO_Li_U As New List(Of Tuple(Of String, Double, Double, Double, Double))
            If oView.Position.X > oPositionX And oView.Position.Y = oPositionY Then 'Ansicht rechts
                Console.WriteLine(oView.Position.X & " ; " & oView.Position.Y)
                valuesRE.Add(Tuple.Create(oView.Name, oView.Position.X, oView.Position.Y, oView.Width, oView.Height))
            ElseIf oView.Position.X < oPositionX And oView.Position.Y = oPositionY Then 'Ansicht links
                valuesLI.Add(Tuple.Create(oView.Name, oView.Position.X, oView.Position.Y, oView.Width, oView.Height))
            ElseIf oView.Position.X = oPositionX And oView.Position.Y < oPositionY Then 'Ansicht unten
                valuesU.Add(Tuple.Create(oView.Name, oView.Position.X, oView.Position.Y, oView.Width, oView.Height))
            ElseIf oView.Position.X = oPositionX And oView.Position.Y > oPositionY Then 'Ansicht oben
                valuesO.Add(Tuple.Create(oView.Name, oView.Position.X, oView.Position.Y, oView.Width, oView.Height))
            ElseIf oView.Position.X > oPositionX And oView.Position.Y > oPositionY Then 'Ansicht ISO rechs oben
                values_ISO_Re_O.Add(Tuple.Create(oView.Name, oView.Position.X, oView.Position.Y, oView.Width, oView.Height))
            ElseIf oView.Position.X < oPositionX And oView.Position.Y > oPositionY Then 'Ansicht ISO links oben
                values_ISO_Li_O.Add(Tuple.Create(oView.Name, oView.Position.X, oView.Position.Y, oView.Width, oView.Height))
            ElseIf oView.Position.X > oPositionX And oView.Position.Y < oPositionY Then 'Ansicht ISO rechs unten
                values_ISO_Re_U.Add(Tuple.Create(oView.Name, oView.Position.X, oView.Position.Y, oView.Width, oView.Height))
            ElseIf oView.Position.X < oPositionX And oView.Position.Y < oPositionY Then 'Ansicht ISO links unten
                values_ISO_Li_U.Add(Tuple.Create(oView.Name, oView.Position.X, oView.Position.Y, oView.Width, oView.Height))
        Next
        valuesRE = valuesRE.OrderBy(Function(i) i.Item2).ToList
        valuesLI = valuesLI.OrderBy(Function(i) i.Item2).ToList
        Dim oRightViewPosition As Point2d = Nothing
        Dim oRightViewPosition1 As Point2d = Nothing
        Dim oRightViewPosition2 As Point2d = Nothing
        Dim oLeftViewPosition As Point2d = Nothing
        Dim oLeftViewPosition1 As Point2d = Nothing
        Dim oLeftViewPosition2 As Point2d = Nothing
        Dim oWidth As Double
        Dim oWidth1 As Double
        Dim oWidth_LI As Double
        Dim oWidth1_LI As Double
        Dim ii_RE As Integer = 1
        Dim ii_Li As Integer = 1
        For Each tpl_Re As Tuple(Of String, Double, Double, Double, Double) In valuesRE
            Console.WriteLine(tpl_Re.Item1 & "-" & tpl_Re.Item2 & "-" & tpl_Re.Item3 & "-" & tpl_Re.Item4 & "-" & tpl_Re.Item5)
                If tpl_Re.Item1 = oView.Name Then
                    If ii_RE = 1 Then
                        oWidth = tpl_Re.Item4
                        oRightViewPosition.X = oPositionX + (oBaseViewWidth) + (tpl_Re.Item5 / 2) + (oAbstand * oScale)
                    ElseIf ii_RE = 2 Then
                        oRightViewPosition1 = m_inventorApp.TransientGeometry.CreatePoint2d()
                        oRightViewPosition1.X = oRightViewPosition.X + (tpl_Re.Item4) + (oAbstand * oScale)
                        oRightViewPosition1.Y = oPositionY
                        oView.Position = oRightViewPosition1
                    ElseIf ii_RE = 3 Then
                        oWidth1 = tpl_Re.Item4
                        oRightViewPosition2 = m_inventorApp.TransientGeometry.CreatePoint2d()
                        oRightViewPosition2.X = oRightViewPosition1.X + (tpl_Re.Item4) + (oAbstand * oScale)
                        oRightViewPosition2.Y = oPositionY
                        oView.Position = oRightViewPosition2
            Next
            ii_RE = ii_RE + 1
            Console.WriteLine(ii_RE.ToString)
        Next
        For Each tpl_Li As Tuple(Of String, Double, Double, Double, Double) In valuesLI
            Console.WriteLine(tpl_Li.Item1 & "-" & tpl_Li.Item2 & "-" & tpl_Li.Item3 & "-" & tpl_Li.Item4 & "-" & tpl_Li.Item5)
                If tpl_Li.Item1 = oView.Name Then
                    If ii_Li = 1 Then
                        oWidth_LI = tpl_Li.Item4
                        oLeftViewPosition.X = oPositionX - (oBaseViewWidth) - (tpl_Li.Item4) - (oAbstand * oScale)
                        oLeftViewPosition.Y = oPositionY
                        oView.Position = oLeftViewPosition
                    ElseIf ii_Li = 2 Then
                        oLeftViewPosition1 = m_inventorApp.TransientGeometry.CreatePoint2d()
                        oLeftViewPosition1.X = oLeftViewPosition.X - (tpl_Li.Item4) - (oAbstand * oScale)
                        oLeftViewPosition1.Y = oPositionY
                        oView.Position = oLeftViewPosition1
                    ElseIf ii_Li = 3 Then
                        oWidth1_LI = tpl_Li.Item4
                        oLeftViewPosition2 = m_inventorApp.TransientGeometry.CreatePoint2d()
                        oLeftViewPosition2.X = oLeftViewPosition1.X - (tpl_Li.Item4) - (oAbstand * oScale)
                        oLeftViewPosition2.Y = oPositionY
                        oView.Position = oLeftViewPosition2
            Next
            ii_Li = ii_Li + 1
            Console.WriteLine(ii_Li.ToString)
        Next
        oTrans.End()
Do you think it could be improved?
Thank you Georg
Message 17 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
My apologies for late reply,
Try below VB.net code to place equidistance between views.
        Dim oSheet As Sheet
        Next
        oListx.Sort()
        oListy.Sort()
        Dim mid As Integer
                midView = oView
                Exit For
        Next
        ' Set prompt.
        ' Set title.
        oAbstand = "80"
            Exit Sub
        'Prüfen, ob Zahlen
        Else
            Exit Sub
        Dim inc_1 As Double = 1
        Dim inc_2 As Double = 1
        Dim inc_3 As Double = 1
        Dim inc_4 As Double = 1
        Dim inc_5 As Double = 1
        Dim inc_6 As Double = 1
        Dim inc_7 As Double = 1
        Dim inc_8 As Double = 1
        Dim dist As Double
                oBaseViewHeight = oView.Height / 2
                oBaseViewWidth = oView.Width / 2
            'End If
            xRange = Math.Abs(Math.Round(oView.Position.X, 2) - Math.Round(oPositionX, 2))
            yRange = Math.Abs(Math.Round(oView.Position.Y, 2) - Math.Round(oPositionY, 2))
                'Ansicht rechts
                dist = oAbstand * inc_1
                oRightViewPosition.X = oPositionX + dist + oBaseViewWidth
                inc_1 = inc_1 + 1
                'Ansicht links
                dist = oAbstand * inc_2
                oRightViewPosition.X = oPositionX - dist - oBaseViewWidth
                inc_2 = inc_2 + 1
                'Ansicht unten
                dist = oAbstand * inc_3
                oRightViewPosition.Y = oPositionY - dist - oBaseViewHeight
                inc_3 = inc_3 + 1
                'Ansicht oben
                dist = oAbstand * inc_4
                oRightViewPosition.Y = oPositionY + dist + oBaseViewHeight
                inc_4 = inc_4 + 1
                dist = oAbstand * inc_5
                oRightViewPosition.Y = oPositionY + oAbstand + oBaseViewHeight
                inc_5 = inc_5 + 1
                dist = oAbstand * inc_6
                inc_6 = inc_6 + 1
                dist = oAbstand * inc_7
                oRightViewPosition.Y = oPositionY - oAbstand - oBaseViewHeight
                inc_7 = inc_7 + 1
                dist = oAbstand * inc_8
                inc_8 = inc_8 + 1
        Next
        oTrans.End()
    End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 18 of 18
GeorgK
great. That rocks. Thank you very much. I almost finished my app.
Georg
