preferred programming language?
Hi
I'm looking to take the leap from iLogic and vba to something more versatile but am unsure which language to dive in to.
I have been searching for clues but have not fund any solid conclusions to what is preferred. it seems to be C# or vb.net
What is the opinion ?
best regards
Martin
Mirtchii
You should choose Visual basic. You can find more information about it as the below image.
bradeneuropeArthur
From vba to vb.net isn't that difficult!
I would advise you to start with visual studio and vb.net!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JamieVJohnson2
I've been using VB.Net.  It is very robust, and everybit as capable as c# (because they both run the .Net CLR).  It is not going away, microsoft won't let it.  The vb.Net language and syntax is the same language that iLogic uses (just different classes are added).  I've used it to perform some very complex tasks, including parallel computing inside of Inventor.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Thanks all for your input. It seems that .net is worth looking in to, even if i do some C when playing with Arduinos
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
calvinjohnson6954
Observer
Observer
 Python continues to be one of the best programming languages every developer should learn this year. The language is easy-to-learn and offers a clean and well-structured code, making it powerful enough to build a decent web application. However, there are many other programming languages that are also very relevant now. For example, my favorite programming language is java script. Although all my colleagues prefer python. Many large companies now conduct it staff augmentation so no one knows when your skills will be useful.
