Hey,
I want to programm a macro with vba which automatically creates a flange.
I need to create a given amount of holes (4, 8, 16, 20) around the middle axis of the flange and I want to use the CircularPatternFeature command.
My current code:
Dim objCol As ObjectCollection
Set objCol = ThisApplication.TransientObjects.CreateObjectCollection
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
Dim oSketch As PlanarSketch
Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
Dim Mp As Point2d 'Mittelpunkt
Set Mp = oTG.CreatePoint2d(0, 0)
Dim Ak As SketchCircle 'Aussenkreis
Set Ak = oSketch.SketchCircles.AddByCenterRadius(Mp, Dm / 2)
Dim oProfile1 As Profile
Set oProfile1 = oSketch.Profiles.AddForSolid
Dim oExtrudeDef1 As ExtrudeDefinition
Set oExtrudeDef1 = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile1, kNewBodyOperation)
Call oExtrudeDef1.SetDistanceExtent(th, kPositiveExtentDirection)
Dim oExtrude1 As ExtrudeFeature
Set oExtrude1 = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef1)
Dim MpL As Point2d 'Mittelpunkt Loch
Set MpL = oTG.CreatePoint2d(LkDm / 2, 0)
Dim KL As SketchCircle 'Kreis Loch
Set KL = oSketch.SketchCircles.AddByCenterRadius(MpL, LDm / 2)
Dim oProfile2 As Profile
Set oProfile2 = oSketch.Profiles.AddForSolid
Dim oExtrudeDef2 As ExtrudeDefinition
Set oExtrudeDef2 = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile2, kIntersectOperation)
Call oExtrudeDef2.SetDistanceExtent(th, kPositiveExtentDirection)
Dim oExtrude2 As ExtrudeFeature
Set oExtrude2 = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef2)
objCol.Add (oExtrude2)
Dim oCircPatternDef As CircularPatternFeatureDefinition
Set oCircPatternDef = oCompDef.Features.CircularPatternFeatures.CreateDefinition(objCol, oCompDef.WorkAxes.Item(3), False, AL, 360 * pi / 180, True)
Dim oCircPattern As CircularPatternFeature
Set oCircPattern = oCompDef.Features.CircularPatternFeatures.AddByDefinition(oCircPatternDef)
When I run this I get the error message 438 "object doesn't support this property or method".
And it highlights the line: objCol.Add (oExtrude2).
The expected variable (oExtrude2) has to be an object but it is a ExtrudeFeature and I don't know how to fix it.
I saw somebody on another forum made it work like this.
Any ideas?
