Help with Circular pattern feature VBA
nilsgam
nilsgam
Hey,
I want to programm a macro with vba which automatically creates a flange.
I need to create a given amount of holes (4, 8, 16, 20) around the middle axis of the flange and I want to use the CircularPatternFeature command.
My current code:
    Dim objCol As ObjectCollection
    Set objCol = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim oSketch As PlanarSketch
    Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
    Dim Mp As Point2d           'Mittelpunkt
    Set Mp = oTG.CreatePoint2d(0, 0)
    Dim Ak As SketchCircle      'Aussenkreis
    Set Ak = oSketch.SketchCircles.AddByCenterRadius(Mp, Dm / 2)
    Dim oProfile1 As Profile
    Set oProfile1 = oSketch.Profiles.AddForSolid
    Dim oExtrudeDef1 As ExtrudeDefinition
    Set oExtrudeDef1 = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile1, kNewBodyOperation)
    Call oExtrudeDef1.SetDistanceExtent(th, kPositiveExtentDirection)
    Dim oExtrude1 As ExtrudeFeature
    Set oExtrude1 = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef1)
    Dim MpL As Point2d          'Mittelpunkt Loch
    Set MpL = oTG.CreatePoint2d(LkDm / 2, 0)
    Dim KL As SketchCircle      'Kreis Loch
    Set KL = oSketch.SketchCircles.AddByCenterRadius(MpL, LDm / 2)
    Dim oProfile2 As Profile
    Set oProfile2 = oSketch.Profiles.AddForSolid
    Dim oExtrudeDef2 As ExtrudeDefinition
    Set oExtrudeDef2 = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile2, kIntersectOperation)
    Call oExtrudeDef2.SetDistanceExtent(th, kPositiveExtentDirection)
    Dim oExtrude2 As ExtrudeFeature
    Set oExtrude2 = oCompDef.Features.ExtrudeFeatures.Add(oExtrudeDef2)
    objCol.Add (oExtrude2)
    Dim oCircPatternDef As CircularPatternFeatureDefinition
    Set oCircPatternDef = oCompDef.Features.CircularPatternFeatures.CreateDefinition(objCol, oCompDef.WorkAxes.Item(3), False, AL, 360 * pi / 180, True)
    Dim oCircPattern As CircularPatternFeature
    Set oCircPattern = oCompDef.Features.CircularPatternFeatures.AddByDefinition(oCircPatternDef)
 When I run this I get the error message 438 "object doesn't support this property or method".
And it highlights the line: objCol.Add (oExtrude2).
The expected variable (oExtrude2) has to be an object but it is a ExtrudeFeature and I don't know how to fix it.
I saw somebody on another forum made it work like this.
Any ideas?
Ralf_Krieg
Hello
Can't explain why, but seems to be related to the intersect extrusion.
Try this one
    Call objCol.Add(Ak)
    Set oProfile1 = oSketch.Profiles.AddForSolid(True, objCol)
    objCol.Clear
    Call objCol.Add(KL)
    Set oProfile2 = oSketch.Profiles.AddForSolid(False, objCol)
    Set oExtrudeDef2 = oCompDef.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile2, kCutOperation)
    objCol.Clear
    Call objCol.Add(oExtrude2)
    Set oCircPatternDef = oCompDef.Features.CircularPatternFeatures.CreateDefinition(objCol, oCompDef.WorkAxes.Item(3), False, AL, 360 * Pi / 180, True)
R. Krieg
RKW Solutions
www.rkw-solutions.com
nilsgam
Thank you this works 🙂
