Macro to export in STEP like my macro PDF
Message 1 of 12
I wish to create a macro for to export my parts and assemblies in STEP files.
I tried to restart of the macro "PDF" (see attached file), but without success.
Where can I find the "key" of the ItemByID("{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxx}")
Like this :
Set PDFAddin = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Thanks by advance
Replies (11)
Message 2 of 12
rossano_praderi
this is a simple Ilogic rule that list all available addins
List = ""
For Each addin In ThisApplication.ApplicationAddIns
	If TypeOf addin Is TranslatorAddIn Then
		List &= addin.DisplayName & addin.ClassIdString & vbCr
	End If
Next
MsgBox(List)
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 3 of 12
Jon.Dean
Did Rossano code help you with your problem?
It seems to feedback the information you was requesting.
Jon.
Jon Dean
Message 4 of 12
This tip helped me, but I trying again to do it work my macro VBA.
Message 5 of 12
VdVeek
There is an example in the API Programming Help under TranslatorAddIn Interface. See Example 5 Export to STEP.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Message 6 of 12
Great !
I didn't know that there are samples to export / save to ...
It's much easier !
I will keep you updated.
Message 7 of 12
I want to export with the filename of the part, but it's doesn't work.
Below my macro VBA, stopped at "FileName = oDocument.FullFileName"
Sub ExportToSTEP()
    ' Get the STEP translator Add-In.
    Dim oSTEPTranslator As TranslatorAddIn
    Set oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
    If oSTEPTranslator Is Nothing Then
        MsgBox "Could not access STEP translator."
        Exit Sub
    End If
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
        ' Set application protocol.
        ' 2 = AP 203 - Configuration Controlled Design
        ' 3 = AP 214 - Automotive Design
        oOptions.Value("ApplicationProtocolType") = 3
        ' Other options...
        'oOptions.Value("Author") = ""
        'oOptions.Value("Authorization") = ""
        'oOptions.Value("Description") = ""
        'oOptions.Value("Organization") = ""
        oContext.Type = kFileBrowseIOMechanism
    'Set filename as original document filename.
    Dim FileName As String
    Dim Temp() As String
    Temp = Split(FileName, "\")
    FileName = Left(Temp(UBound(Temp)), Len(Temp(UBound(Temp))) - 4)
    'Set the destination to save files.
    Dim oDocRevision As Property
    Dim Revision As String
    Set oDocRevision = oDocument.PropertySets.Item("Inventor Summary Information").Item("Revision Number")
        If oDocRevision.Value = "" Then
            oDataMedium.FileName = "C:\Users\amn\Desktop\" & FileName & ".stp"
        Else
            Revision = "_" + CStr(oDocRevision.Value)
            oDataMedium.FileName = "C:\Users\amn\Desktop\" & FileName & Revision & ".stp"
        End If
        Dim oData As DataMedium
        Set oData = ThisApplication.TransientObjects.CreateDataMedium
    'Publish document.
    Call oSTEPTranslator.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
    End If
End Sub
Message 8 of 12
VdVeek
In the line where the error occurred, you are referring to oDocument but you didn't create the oDocument in your code.
If you create the oDocument and Set it to the active document than the code should work.
Dim oDocument As PartDocument
Set oDocument = ThisApplication.ActiveDocument
 Rob.
Message 9 of 12
rolf_zimmermann
Dear all,
I need a macro to export a specific representation view to STP, not the whole model.
How can I do that with the macro ?
Kind regards
Rolf
Message 10 of 12
MechMachineMan
Hah. Don't think you can. Probably have to make a new .iam that only contains those components that match that view rep and export that.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 11 of 12
VdVeek
When you manualy make a step, it exports the model as the active LOD. So i think when you first let your code activate the LOD that the rest of the script will use that LOD.
Message 12 of 12
rolf_zimmermann
Thank you, yes this works.
