Exporting entire VBA projects to compare version changes
I'm using Inventor 2015
I'd like to create a VB.NET app that can compare different versions of an entire VBA project.
To do this I would like to programmically export an entire VBA project in one go.
In VB.NET I imported the Microsoft VBA Extensibilty class,
but I have no way to connect it to the stand alone External VBA project file that inventor uses.
Normally with office products I could make a reference to say an Excel or Word document then
Connect my VBE object to its VBA project object.
Is there any sample code available to export the code from Inventors External VBA project?
Issue resolved.
Here is the final generic VBA tool I came up with.
Feel free to use it if necessary.
With MS Office docs you do not need to go to these lengths as VBA is saved inside the Office docs.
With Inventor and Autocad they are External files.
VBA code follows
Code:
Option Explicit
Public Sub DumpAllVbaProjectCode()
  ' This utility was written for 64 bit Inventor 2015. Untested with 32 bit.
  ' Make sure to reference VBE (Microsoft Visual Basic for Applications Extensibility 5.3
  ' You may have to browse to the file containing the reference:
  ' C:\Program Files (x86)\Common Files\Microsoft Shared\VBA\VB6\VBE6EXT.OLB
  Const vbext_ct_StdModule = 1
  Const vbext_ct_ClassModule = 2
  Const vbext_ct_MSForm = 3
  Const vbext_ct_Document = 100
  Dim oModule As InventorVBAComponent
  Dim sOut As String
  sOut = ""
  For Each oModule In ThisApplication.VBAProjects(1).InventorVBAComponents
    With oModule.VBComponent
      If .Type >= vbext_ct_StdModule And .Type <= vbext_ct_Document Then
        Dim PadLine As String
        If sOut = "" Then
          PadLine = ""
        Else
          PadLine = vbCrLf
        sOut = sOut & PadLine & "' \\\ " & oModule.Name & " ///" & vbCrLf
        Dim oCodeModule As CodeModule
        Set oCodeModule = oModule.VBComponent.CodeModule
        sOut = sOut & CleanString(oCodeModule.Lines(1, oCodeModule.CountOfLines)) & vbCrLf
    End With
  Next
  Open "C:\VBA_Dump.txt" For Output As #1
    Print #1, sOut
  Close #1
  MsgBox "VBA Project Dumped"
End Sub
Public Function CleanString(STR As String) As String
  ' Formalizes the output so it may be compared with other versions of the project.
  Dim sLines() As String
  Dim sOut As String
  Dim i As Integer
  ' remove tabs
  STR = Replace(STR, vbTab, "")
  sLines = Split(STR, vbCrLf)
  For i = 0 To UBound(sLines) - 1
    sLines(i) = RTrim(sLines(i))
    If Not (sLines(i) = RTrim(sLines(i + 1)) And sLines(i) = "") Then
      ' construct new string
      sOut = sOut & sLines(i) & vbCrLf
  Next i
  Do
    ' Clean up trailing newlines
    If Right$(sOut, 2) = vbCrLf Then
      sOut = Left$(sOut, Len(sOut) - 2)
  Loop Until Right$(sOut, 2) <> vbCrLf
  CleanString = Trim(sOut)
End Function
