Hi all,
In Inventor 2021 we used to be able to derived a part's sketches and toggle lines from construction to solid and vice versa. Seems like in Inventor 2022 they have disabled this function. Can you please re-enable this? Now our current work-around is to create a new sketch and project those lines. Adding an unnecessary step...
Hi @iUser
This is really no good situation I think!
What happens during migration?
This was possible in earlier releases of inventor and now not anymore.
Will this lead into problems when files are migrated with construction-lines into normal lines, I think YES.
@johnsonshiue Could you check with the team if this is the case:
I really hope that Inventor 2022 will not give that much problems for users also regarding other changes!
Regards
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Having similar issue with this and need some feed back as soon as possible. Our company uses this function all the time and has many files using this feature. we just recently updating to 2022 so it wasn't an issue until now. Please let me know if there is some feature check box we need to check. Thanks.
@johnsonshiue could you please check for a solution for all of us!
Thanks in advance.
Arthur Knoors
I have real big problems with this change too.
@johnsonshiue Could you please be so kind to help us with a solution.
Arthur Knoors
@johnsonshiue or @Yijiang.Cai could you guys please have a look at this? Its starting to cause more and more issues and the work arounds are starting to cost us time and money.
Please read this:
Think that the issue has been taken serious now from the development team!
Thanks again @johnsonshiue for taking this serious!
Arthur Knoors
@iUser , today I talked with @johnsonshiue about this issue, and Johnson is working with project team on it.
@johnsonshiue , please feel free to share more details here if you have.
