iLogic Inventor Drawing Save As
I have a rule that runs a part drawing to save as after I put a new part in it.   When I start with and "idw" drawing file everything is fine.
ThisDoc.Document.SaveAs(ThisDoc.Path & "\" & RtrnSpannerPnNo & ".idw", True)
Problem I have is that there are lots of drawings that I want to reference and save as on that are Inventor based .dwg  files.  When I swap out ".idw" with ".dwg", I get a new file that is actually correct, but it is an autocad .dwg that is not tied to model.  How can I get the SaveAs to pick Inventor based .dwg?
MechMachineMan
As you would have seen had you looked in Programming Help....
DrawingDocument.SaveAsInventorDWG Method
Syntax
DrawingDocument.SaveAsInventorDWG( FullFileName As String, SaveCopyAs As Boolean )
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Jonathan.Landeros
Thanks!
I was wondering the exact thing myself.  Ironically, looking in the first place is the last thing that I thought of.
Lesson learned!  Now to give it a go!
It is possible to fly without motors, but not without knowledge and skill.
Wilbur Wright
I didn't even know it existed, so I got a two for one!
